ev3 BCC/C: plugged USB keyboard as an input/ stdin device?
Posted: 20 Dec 2013, 14:14
hey,
how can I use a USB keyboard plugged to the ev3 master USB port as a stdin device?
My program is currently not working.
What I'm trying is the following - is there maybe just a mistake by using pointers or is a USB keyboard device driver missing for Lego Linux ?
edit - now completely new from scratch:
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include "lms2012.h"
#include "ev3_button.h"
#include "ev3_lcd.h"
#define msleep(t) usleep(1000*t)
int main()
char text[120], tdx;
int key, c[120];
ButtonLedInit();
LcdInit();
LcdClean();
c[0]=32;
tdx=0;
while(1)
LcdClean();
while((key=getchar())!=10) { // read input line until [ENTER]
if((key>31)&&(key<128)) { // printable kbd code
c[tdx]=key;
text[tdx]=(char)key; // character to text string
LcdText(1, 0, 10, text) ; // no autom. echo on screen
tdx++; // text buffer counter
if(ButtonWaitForAnyPress(100) == BUTTON_ID_ESCAPE)
break;
msleep(5);
LcdExit();
ButtonLedExit();
return 1;
(now the lcd is cleared, but then the ev3 hangs up, no reaction to USB kbd press, batteries have to be removed)
Re: ev3 BCC/C: plugged USB keyboard as a stdin device?
Posted: 21 Dec 2013, 10:21
by mightor
This as much effort as I can put into this. It works on my Ubuntu Linux VM and it should work with an EV3 brick. Experiment with the /dev/input/event<number>. You may need to use 0 or 1 or maybe even 2, I don't know. Play with it.
Taken and adapted from
http://rico-studio.com/linux/read-and-w ... rd-device/
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <linux/input.h>
#include <stdio.h>
#define EV_PRESSED 1
#define EV_RELEASED 0
#define EV_REPEAT 2
void main()
int fd = 0;
// Not sure if this has to be event0 or event1 on the EV3
char *device = "/dev/input/event1";
struct input_event event;
unsigned int scan_code = 0;
if( (fd = open(device, O_RDWR)) > 0 )
while (1 == 1)
int num_bytes = read(fd, &event, sizeof(struct input_event));
if(event.type != EV_KEY)
continue;
if(event.value == EV_RELEASED)
// This is the key that is pressed.
// To see which code means which key, take a look here:
// http://www.cs.fsu.edu/~baker/devices/lxr/http/source/linux/include/linux/input.h?v=2.6.11.8
// Use an array to map this value to the real character, should be trivial using the info in the link above.
scan_code = event.code;
printf("code: %d\n", scan_code);
fprintf(stderr, "Could not open keyboard device!\n");
= Xander
Posted: 21 Dec 2013, 16:43
thank you,
now this one was actually really useful.
As a small contribution from me in return, here's the code to read keys by their ASCII value from a USB keyboard plugged to the EV3 -
Numpad numbers are working , shift and capslock is working, but shift is a little shaky because 2 keys are read shortly behind one another
(different from common PC kbd scancodes - no idea how to poll if 2 keys are pressed simultaneously).
the keys are for German kbd layout (QWERTZ),
for different layouts you'll have to change the characters of the letter QWERTZ[] string accordingly
(maybe copy QWERTZ[] to QWERTY[] and overwrite the entries).
initialize by init_USBkbd()
function call by
int key=getcharUSB();
Posted: 22 Dec 2013, 19:54
there is a bug I cannot fix:
if I print the whole string to which the key is added then there is always a
at the 1st position.
e.g., if I enter
1234
it is shown
\1234
2nd problem:
in the line
(event.type != EV_KEY) ...
what is EV_KEY? it's no where been declared AFAIK...?
3rd problem:
at the first call the function appears not to wait for a keypress but runs through,
it just then waits for the 2nd, 3rd, 4th keypress and so on
(what maybe is the reason for the odd output).
what is wrong?
// read letters from USB keyboard plugged to EV3
// readkeys.c
// ver. 1.02
// read USB kbd keys by: int getcharUSB()
// credits to Xander Soldaat
// reference:
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
//#include "lms2012.h" // still shaky because of re-definitions
#define cls() LcdClean() // more C-like
#define mline 118 // line for status msg
// USB kbd device
#define EV_REPEAT 2
// QWERTZ = German kbd layout representation
// uppercase overhead = 128
char QWERTZ[]= " 1234567890-= qwertzuiopü+ asdfghjklöä# <yxcvbnm,.- * 789-456+1230, !'§$%&/()=?` QWERTZUIOPÜ* ASDFGHJKLÖÄ' >YXCVBNM;:_......";
#define KEY_UPPEROVHD 130 // uppercase overhead = 128
#define KEY_LEFTSHIFT 42 // kbd keycode
#define KEY_RIGHTSHIFT 54 // kbd keycode
#define KEY_CAPSLOCK 58 // kbd keycode
int _kbd_fd_; // kbd file dev handle
char init_USBkbd() {
char *device = "/dev/input/event0"; // event1: hangs up after cls
_kbd_fd_ = 0;
if ( (_kbd_fd_ = open(device, O_RDWR)) > 0 ) return 1;
else return 0;
int getcharUSB() {
int keycode;
char buf[10];
int retval;
static int UPCASE;
static char LEFTSHIFTTMP;
int num_bytes;
while (event.type != EV_KEY) {
num_bytes = read(_kbd_fd_, &event, sizeof(struct input_event));
keycode = event.code;
if(keycode==KEY_CAPSLOCK) {
UPCASE=(UPCASE==0)?KEY_UPPEROVHD:0;
return 0;
// SHIFT for uppercase
if ( (keycode==KEY_LEFTSHIFT)||(keycode==KEY_RIGHTSHIFT) ) {
UPCASE=(UPCASE==0)?KEY_UPPEROVHD:0; // (still shaky)
LEFTSHIFTTMP=1;
return 0;
if(keycode== 1) retval=27; // KEY_ESCAPE
if( (keycode==28)||(keycode==96) ) retval=10; // KEY_ENTER
if(keycode==14) retval=8; // KEY_BACKSPACE
retval= QWERTZ[keycode+UPCASE] ;
if (LEFTSHIFTTMP) { // SHIFT for uppercase
LEFTSHIFTTMP=0;
// debug:
//sprintf(buf,"keycode:%3d ASCII:%3d", keycode,retval); LcdText(1, 0,20, buf);
return ( retval );
// task main()
// how to initialize and how to call
int main()
int key = 0, i=0;
char buf[120], text[120]; // text string
ButtonLedInit();
LcdInit();
cls();
if (!init_USBkbd()) {
LcdText(1, 0, mline, "keyboard device error! ");
Wait(2000);
goto quit;
LcdText(1, 0, mline, "press keys on keyboard! ");
text[0]='\0';
while (1) {
key=getcharUSB(); // read kbd kbdkeycode => ASCII code
// now what to do with the key ?
if (key==27) goto quit; // 27 = ESC => stop program
if(key>32) {
// add key to string
text[i+1]='\0';
text[i] =key;
sprintf(buf,"%c ", key);
LcdText(1, 0,10, buf); // display key
LcdText(1, 0,40, text); // display string
i++;
Wait(1);
quit:
LcdText(1, 0, 10, " ");
LcdText(1, 0, mline, "program terminated ");
Wait(500);
cls();
Wait(10);
LcdExit();
ButtonLedExit();
return 1;
Posted: 23 Dec 2013, 05:37
by mightor
I don't have the standard firmware on any of my bricks, nor the BCC C library, but the program seems to function just fine for me. I modified to allow me to compile it on my Ubuntu VM. I ran it in one window and typed in another:
EV_KEY is the type of event that a keyboard generates. Did you look in the link I provided in the source code for input.h? It has to be declared, you would get a compile error if it hadn't.
To make your code a bit saner, avoid using gotos and change your keycode if statements to a switch/case block.
My modified code:
// readkeys.c
// ver. 1.02
// reference:
// #define EV3
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
#ifdef EV3
#endif
// USB kbd device
#define EV_REPEAT 2
#ifdef EV3
#define KEYBOARD_DEVNAME "/dev/input/event0"
#else
#define KEYBOARD_DEVNAME "/dev/input/event1"
#endif
char *device = KEYBOARD_DEVNAME; // event1: hangs up after cls
_kbd_fd_ = 0;
else return 0;
int getcharUSB() {
int keycode;
char buf[10];
int retval;
static int UPCASE;
int num_bytes;
return 0;
LEFTSHIFTTMP=1;
return 0;
LEFTSHIFTTMP=0;
#ifdef EV3
// debug:
#else
fprintf(stderr, "keycode:%3d ASCII:%3d\n", keycode,retval);
#endif
return ( retval );
// task main()
int main()
int key = 0, i=0;
#ifdef EV3
ButtonLedInit();
LcdInit();
cls();
#endif
#ifdef EV3
Wait(2000);
#else
fprintf(stderr, "keyboard device error!\n");
#endif
goto quit;
#ifdef EV3
#else
printf("Press keys on keyboard!\n");
#endif
text[0]='\0';
while (1) {
if(key>32) {
text[i+1]='\0';
text[i] =key;
#ifdef EV3
#else
printf("buf: %s, text: %s\n", buf, text);
#endif
i++;
#ifdef EV3
Wait(1);
#else
sleep(1);
#endif
// Using a goto is a big nono if you can solve the issue
// with a simple function call. This is nasty.
quit:
#ifdef EV3
Wait(500);
cls();
Wait(10);
LcdExit();
ButtonLedExit();
#else
fprintf(stderr, "Program terminated\n");
#endif
return 1;
Posted: 23 Dec 2013, 08:39
thank you for your efforts!
but strangly the problem remains:
on the ev3 screen the text string is always displayed with a leading "\".
There must be issues about the string handling or the string out function - but I have no idea what's faulty.
edit:
indeed lcdline seems not to be able to display the string correctly:
LcdText(1, 0,40, text); // display string // always a leading \
sprintf(buf, text); LcdText(1, 0,40, buf); // display string // no output at all
Posted: 23 Dec 2013, 18:11
update:
Now it just displays the key but doesn't display the combined string any longer at all.
But as it works with Xander's konsole version as expected, there must be severe bugs in John's lcd header, epecially to display strings on the lcd
(but also LcdClean is bugged).
// kbdUSB.c
// ver. 1.04
// reference:
// define EV3
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
// USB kbd device
#define EV_REPEAT 2
// diphthongs/umlaut diacritics äÄ,öÖ,üÜ,ß, and accents ´` not displayable; patch for ß=\ ü=| ö=[ ä=] Ü=~ Ö={ Ä=} `=@
char QWERTZ[]= " 1234567890\\@ qwertzuiop|+ asdfghjkl[] #yxcvbnm,.- * 789-456+1230, < !'§$%&/()=?@ QWERTZUIOP~* ASDFGHJKL{} 'YXCVBNM;:_ > ";
#define CAPSSTROVHD 130 // uppercase overhead in QWERTZ string
_kbd_fd_ = 0;
else return 0;
int getcharUSB() {
int keycode;
char buf[10];
int retval;
static int UPCASE;
static char SHIFTTMP;
int num_bytes;
UPCASE=(UPCASE==0)?CAPSSTROVHD:0;
return 0;
UPCASE=(UPCASE==0)?CAPSSTROVHD:0; // (still shaky)
SHIFTTMP=1;
return 0;
if( (keycode==28)||(keycode==96) ) retval=10; // KEY_ENTER left/right
if (SHIFTTMP) { // SHIFT for uppercase
SHIFTTMP=0;
// debug:
return ( retval );
// task main()
int main()
int key = 0, ci=0;
char buf[20], text[120]; // text string
ButtonLedInit();
LcdInit();
cls();
sprintf(buf,"keyboard device error! "); LcdText(1, 0, mline, buf);
Wait(2000);
goto quit;
sprintf(buf,"press kbd keys! "); LcdText(1, 0, mline, buf);
text[0]='\0';
while (1) {
// wait for key-press on keyboard
// wait for key-up
if(key>31) { // printable key
text[ci] =key; // add key to string (char array)
text[ci+1]='\0'; // null-terminated string
sprintf(buf,"%c ", key); // display key numbers as letters
// display string
LcdText(1, 0,40, text); // <<<<<<<<<<< BUG !!! Not executed!
ci++;
Wait(1);
quit:
cls();
Wait(500);
cls(); // <<<<<<<<<<< BUG !!! Not executed!
Wait(10);
LcdExit();
ButtonLedExit();
return 1;
Posted: 26 Dec 2013, 13:18
I tried to make it run, but no chance -
although the keys are read correctly from keyboard I can't make BCC/C add them to a string and display the string on the screen.
If we only could use the C-functions like getchar, gets (with screen-echo) and also printf like by stdio.h in a console !
I guess I must give up.
