Moving heavy objects
Posted: 21 Nov 2013, 17:45
I have a project I'm working on that requires rotating a small 3-5 lbs object and I'm looking for suggestions or examples of ways the NXT (motors) can handle that.
Since I don't have to actually grab anything, it seems like a simple project, but have found a few issues. Mainly handling the weight is the problem.
I have built a basic frame for what I need, and have revised it several times already. Sorry, cannot go into detail as I'm hoping I can use this at work.
But some basic concepts I am using / coming to grips with are;
* Center of gravity. Keeping item centered to avoid balance problems.
* Using more than 1 motor. Already having issues with controlling power with 1 motor.
* Rotational momentum. Think I need to gear down to control this. I'm at 1:2.33 now, and still have issues. More than 1 motor may solve this issue.
* Holding item down? I'm hoping gravity will do the work for me. Some rubber parts should keep the thing in place.
* Struts/caster supports. I have some good struts in my frame, but may need additional support for the weight. Thinking about adding casters the the bottom to keep it level...
Any examples/ideas along these lines would be great.
