Motor and Sensor ports dead after recharging
Posted: 04 Nov 2013, 21:17
				I have a fairly simple line following NXT robot, programmed in NXC.  It has the newer white battery. I've had it for
over a year, running the same program, as I use it for school demos. I ran it; all was okay; I put it on charge for
several hours. I put it on the test track, turned it on, and got the standard ta ta ta da. I clicked through to the
program and clicked run. I noticed the sensor lights did not come on, and no motor started. I tried several times.
Then I hooked it up to the PC, downloaded the program, and tried again same thing; no luck. I took an NXT from
another robot, downloaded the program, hooked up the motors and sensors, and it ran. So the sensors and motors
are okay. It as if recharging burned out something in all the motor and sensor ports on the first NXT. Has anyone
seen a similar problem. Is there any easy cure. Thanks for any ideas.
Howard
Howard
