NXC: MotorOverload always returns false
avcampos
Post by avcampos »
Hi all!
I'm programming a robot that has limited travel on one of its articulations. I don't require precision on its position, just that it stops the motor as soon as it hits the limit.
NXC has the MotorOverLoad function, which appears to do exactly what I want... however, it always returns "false" even if the motor is completely stalled! Digging a bit, I found that MotorOverload is actually a shortcut for one of the fields of GetOutput (like "GetOutput(OUT_A, OverloadField)"). Checking the field's documentation, I see that, for it to work, I need to set the motor according to numerous parametres... but, after setting them, I can't get the motor to actually run!
This is what I wrote to get the motor running, while hopefully enabling MotorOverload:
SetOutput(
	OUT_C,
	OutputModeField, OUT_MODE_MOTORON + OUT_MODE_REGULATED,
	RegModeField, OUT_REGMODE_SPEED,
	PowerField, power_C * d);
If I use the normal "OnFwd" instead, the motor is never stopped:
if(MotorOverload(OUT_C))
	Stop(OUT_C);
What could I be doing wrong? Thanks in advance!
Re: NXC: MotorOverload always returns false
You can use OnFwdReg with the OUT_REGMODE_SPEED regmode constant
http://bricxcc.sourceforge.net/nbc/nxcd ... ff41f147f5
This API function will run the motor with all the required parameters for the overload field to potentially be non-zero. Make sure you use a power level < 100. Then hold onto the axle so that is slows significantly for a long enough period of time that your call to MotorOverlad would catch a point in time where the speed regulation was unable to maintain the set speed (e.g., 75) even at its highest power levels. That should return a non-zero value in that case.
Have a look at the OnFwdReg macros in NXTDEFS.h to see how you could use SetOutput to do the same thing.
#define OnFwdRegEx(ports, pwr, regmode, reset) setout ports, Power, pwr, OutputMode, OUT_MODE_MOTORON+OUT_MODE_REGULATED+OUT_MODE_BRAKE, RegMode, regmode, RunState, OUT_RUNSTATE_RUNNING, TachoLimit, 0, UpdateFlags, UF_UPDATE_TACHO_LIMIT+UF_UPDATE_MODE+UF_UPDATE_SPEED+reset
In your code you were missing the update flags which is crucial to telling the firmware which fields were updated by the call. Otherwise it waits for a subsequent SetOutput which sets those update flags and does nothing.
pepijndevos
Post by pepijndevos »
Actually, I have some code for this laying around: http://studl.es/2012/03/explorer-robot-without-sensors/
-- Pepijn
avcampos
Post by avcampos »
Thanks for your answers! Indeed, using OnFwdReg was the key... I had no idea that, for SetOutut to enable the GetOutput fields I had to also set update flags! I really spent too much time with the RCX before moving to the NXT...
Anyway, I ended up not using MotorOverLoad, as I noticed the motor spent some time trying to overcome its limit before giving up; and, since the motor is to move in short bursts, this time is considerable. So I went instead for MotorActualSpeed, which gives up earlier:
if(abs(MotorActualSpeed(OUT_C)) > 75)
	Off(OUT_C);
	stall_C = sign(MotorActualSpeed(OUT_C)); //Won't try moving in this direction next time
pepijndevos wrote:Actually, I have some code for this laying around: http://studl.es/2012/03/explorer-robot-without-sensors/
That's a very interesting solution to spare sensors! But I guess the obstacle detection accuracy would be very dependent on ground friction (false negatives) and inclination (false positives).
