NXC: problem with reading out the servo position
Posted: 23 Aug 2013, 14:30
I have several Hitec Servos connected to a Mindsensors NXTServo-v3 Servo module
and tried to add some code to the original NXC library so that I can read out the current position of
a servo.
For testing purpose I just coded a routine routine for port 1 on the controller board.
Here´s the function I added to the library:
It seems that this is working. SOMEHOW......
......because I have to call this function twice each time I want to read the position.......
So, what´s wrong with my function? Any ideas?
I read in the general I2C documentation, that you have to start the reading with a write command.
As I2CBytes seems to be the higher-level wrapper for this You shouldn´t need it.
Or am I missing something?
Any help/hint is wellcom.
Thanks in advance
noob
a servo.
void ShowServo1Position(byte prt, byte adr, byte reg)
  SetSensorLowspeed(prt);
  int result = -1;
  int cnt = 2;
  byte outbuf[];
  byte cmdbuf[];
  byte nByteReady = 0;
  string pos;
  ArrayBuild(cmdbuf, adr, reg);
  while (I2CStatus(prt, nByteReady) ==  STAT_COMM_PENDING)
      Wait(10);
  if(I2CBytes(prt, cmdbuf, cnt, outbuf))
    result = outbuf[0];
    if(cnt==2)
      result = result + outbuf[1]*256;
  pos = NumToStr(result);
  TextOut(0, LCD_LINE4, pos, true);
#include "180813_lib.nxc"
#define SensorPort S1
const byte ServoAddr = 0xb0;
task main ()
   SetSensorLowspeed(SensorPort);
   SetServoSpeed(SensorPort, ServoAddr, 1, 100);
   while(true)
      QuickServoSetup(SensorPort, ServoAddr, 1, 50);
      Wait (2000);
      ShowServo1Position(SensorPort, ServoAddr, 0x42);
      QuickServoSetup(SensorPort, ServoAddr, 1, 200);
      Wait (2000);
Thanks in advance
noob
