NXC: program blocks caused by PlayTones()
I added some PlayTones() to my program for status signalizing and debugging.
Now after playing the sound melody the program flow always blocks (freezes), the NXT makes a frequently cheeping noise (> 10kHz) or the motor mux crackles -
and nothing happens to the program any more.
Tone sndChordUp[]   = {TONE_C4,50, TONE_E4,50, TONE_G4,50,
                        TONE_C5,50, TONE_E5,50, TONE_G5,50, TONE_C6,200};
  PlayTones(sndChordUp);
Anyway, it still is reacting to a touch pressure polled by an Emergency Stop tasks.
This malfunction is new since I'm using a touch muxer (homebrewed PCF8574) and a motor muxer (MS_MTRMX) instead of a 2nd NXT (formerly paired shakily by BT)
- I'm not sure if an interference with a muxer is the reason why.
if I remove the Playtones() command then the program runs fine.
here's a snippet:
task main(){
  char EP,                            // flag: en passant
       RK,                            // flag: castling=Rochade
       CK, CM,                        // flag: check!=Schach! (1&8, 1&16)
       turn,                          // side on turn
       chosen;                        // manual or auto move from stdin input;
  char board[129];                    // Piece K_start-> L_dest
  int K, L,                           // score local, remote
      score, rscore1, rscore2, rscore3, idum, buf;
  char PMOD=0, m1, m2, m3;
  string s;
// init all defauts
  Init();
  InitIOports();
  InitLookupTable();
  start EmergencyStop;
  start GetPCF8574Values;
  start PneumPressurePump;
  start DisplayValues;
// chess robot setup
  Claw_close(); Wait(500);
  Claw_open();  Wait(500);
  Hand_up();    while (!SensorT_Cup);
  RobotArmsZeroInit();
  PlayTones(sndChordUp);            // <<<< blocks if not outcommented
  // align board center base line
  statusline="=> sqr. 128  ";
  MoveClawTo(128);
  Coast(OUT_ABC); Wait(200);
  // single chess square alignment
  Hand_up();  while (!SensorT_Cup);  Claw_open();
  stop DisplayValues; statusline=clrln;
  buf=Menu("Calibrate ?", "/9  /ALL  /no");
the whole NXC code:
chess 459singleNXT.zip
main program, motor and sensor control
(6.86 KiB) Downloaded 709 times
CHESS_AI_ENGINE_H.zip
chess engine & toolbox
(11.48 KiB) Downloaded 776 times
any ideas?
Re: NXC: program blocks caused by PlayTones()
has no one an idea why Playtones() can block up a program?
I'm inclined to think it is because this function is getting called on two separate threads simultaneously. I didn't analyze the full program to say whether it is doing that or not. But it is not inline or safecall so if you do call it in a subroutine (inline or not) that gets called from a thread other than main you could get a lockup due to the fact that non-inline and non-safecall functions are not thread safe and care must be taken that they are not called at the same time from two different threads.
You could declare a mutex globally called "mutexSoundSystem" and acquire it before calling PlayTones and release it after calling PlayTones everwhere that you call PlayTones and see if that makes the problem go away.
John, thank you for your hint.
I added
 mutex tmutex;
safecall void PlayTonesSCall(Tone snd[]) {
  Acquire(tmutex);
  PlayTones (snd);
  Release(tmutex);
I replaced all PlayTones in every function or task by PlayTonesSCall - but it all is still the same malfunction: the robot plays the sound but then immediately hangs up.
no ideas any more...?
I would try to create a simple test program that locks up when you use PlayTones. You can try replacing PlayTones with its equivalent. It just iterates through an array of Tone structures and calls PlayTone for each one.
edit: aahm - no - I don't actually get what you mean
simple programs did never block, even before it didn't ever block, but now my big one including the 2 muxers blocked unforeseen.
But I replaced all
  Acquire(tmutex);
  PlayTones (snd);
  Release(tmutex);
by
safecall void beep(int frq, int dur) {
   PlayTone(frq, dur); Wait(dur);
and now it works fine again.
surprise, surprise... :o
@John:
no idea why PlayTones() blocks while PlayTone() doesn't?
(actually there is no PlayTone(s) contemporaneously in different tasks)
could it be that the PlayTones-running task blocks because PlayTones doesn't use proportionate long wait states internally after playing each single tone?
Maybe thus the scheduler conflicts with other running tasks?
Here is the definition of PlayTones from the NXCDefs.h header file.
void PlayTones(Tone tones[])
  for (int i = 0; i <  asm { arrsize __RETVAL__, tones }; i++) {
    Tone tmp = tones[i];
    PlayTone(tmp.Frequency, tmp.Duration);
    asm { waitv tmp.Duration };
Feel free to fiddle with this to see where it might be going wrong. Certainly you can't call this non-inline, non-safecall function from more than one thread simultaneously.
Users browsing this forum: Semrush [Bot] and 9 guests
