NQC Compiler Errors using Arrays
Posted: 30 Mar 2013, 15:14
Hi All,
I'm having issues with NQC Compiler Errors with Arrays. I've dusted of my old RCX's for a local LEGO Expo next month. I decided to build Mario Ferrari's 'Learning Brick Sorter' from the Mindstorms Masterpieces book.
I built the same robot 6-8 years ago and was able to compile the code and run the robot. This time around I can't get the following code to compile, and producing without errors the "Error: RCX does not support arrays", on Lines 25, 26, 27.
Any help would be much appreciated.
Learning brick sorter
Author: Mario Ferrari
Date: January 2003
#define BINS 3
#define RANGES 3
#define SWITCH_TIME 20
#define LITE_THRSHLD 98
#define OP_DELAY 75
#define RANGE_WIDTH 2
#define KB_YES 1
#define KB_NO -1
#define KB_UNKNOWN 0
int range; // index of the selected range (0 based)
int top_range; // highest used range index
int bin; // index of the selected bin (0 based)
int pos; // current arm position: -1=pick up station, 0=bin0, 1=bin1...
int min[RANGES]; // lower limits of the ranges
int max[RANGES]; // upper limits of the ranges
int kb[RANGES*BINS]; // the knowledge base
SystemSetup();
while (true)
// wait for button pressed
while (SENSOR_1 < LITE_THRSHLD && SENSOR_2 == 0);
PlaySound(SOUND_CLICK);
// analyze knowledge base (set the range & bin variable)
Analyze();
// take the brick
LowerArm();
Wait(OP_DELAY);
CloseHand();
Wait(OP_DELAY);
LiftArm();
// go to bin and drop it
Move(bin);
OpenHand();
// wait for user input
while (SENSOR_1 <LITE_THRSHLD && SENSOR_2 == 0);
// update knowledge base
if (SENSOR_2 == 1) // wrong
PlaySound(SOUND_LOW_BEEP);
Wait(OP_DELAY);
UpdateKnowledgeBase(false);
else // right
PlaySound(SOUND_DOUBLE_BEEP);
Wait(OP_DELAY);
UpdateKnowledgeBase(true);
// go back to pick up station
Move(-1);
void SystemSetup()
int i;
SetSensor(SENSOR_1, SENSOR_LIGHT);
SetSensor(SENSOR_2, SENSOR_TOUCH);
SetSensor(SENSOR_3, SENSOR_TOUCH);
pos = -1; // initial position is pick-up station
top_range = -1; // means no range is yet defined
// clear the knowledge base
for (i=0;i<BINS*RANGES;i++) kb[i]=KB_UNKNOWN;
SetUserDisplay(range*100+bin,2);
void Analyze()
int light_value;
// wait for coupled touch sensor released
while (SENSOR_1>LITE_THRSHLD);
light_value = SENSOR_1;
// search if the light value is contained in one of the already defined ranges
for(range=0;range<=top_range;range++) {
if (light_value>=min[range] && light_value<=max[range]) break;
// if not, define a new range
if (range>top_range) {
top_range++;
// if all ranges have been used, beep for error and terminate program
if (top_range>=RANGES) {
PlaySound(SOUND_DOWN);
StopAllTasks();
range=top_range;
min[range]=light_value-RANGE_WIDTH;
max[range]=light_value+RANGE_WIDTH;
// look for a positive value in the knowledge base array
for (bin=0;bin<BINS;bin++)
if (kb[range*BINS+bin]==KB_YES) return;
// otherwise, look for an "unknown" value in the knowledge base array
if (kb[range*BINS+bin]==KB_UNKNOWN) return;
// this point shouldn't ever be reached, unless the user provided some
// inconsistent replies. If this happens, the program makes a random choice.
bin=Random(BINS-1);
void UpdateKnowledgeBase(int ok)
int r;
// the user said OK
if (ok)
// this bin is the right one for the given range...
kb[range*3+bin]=KB_YES;
// ...and the wrong one for the other ranges
for(r=0;r<RANGES;r++)
if (r!=range)
kb[r*BINS+bin]=KB_NO;
// the user said NO
// the bin is the wrong one
kb[range*BINS+bin]=KB_NO;
void Move(int dest)
int dir;
// if arm is already at proper position, exit
if (dest == pos) return;
// set direction according to the difference between
// the current position and the required destination
if (dest > pos)
dir = 1;
OnRev(OUT_A);
dir = -1;
OnFwd(OUT_A);
// move until destination is reached
while (dest != pos)
while (SENSOR_3 == 1); // wait for sensor open
while (SENSOR_3 == 0); // wait for sensor closed again
pos += dir;
Off(OUT_A);
void OpenHand()
OnFwd(OUT_C);
Wait(SWITCH_TIME);
Off(OUT_C);
void CloseHand()
OnRev(OUT_C);
Wait(SWITCH_TIME);
Off(OUT_C);
void LiftArm()
OnFwd(OUT_B);
Wait(SWITCH_TIME);
Off(OUT_B);
void LowerArm()
OnRev(OUT_B);
Wait(SWITCH_TIME);
Off(OUT_B);
