Read Ultrasonic Sensor with MindSqualls
Posted: 22 Dec 2012, 01:31
I am trying to create a simple program in VB.NET with the MindSqualls .NET libaray v2.2 (http://www.mindsqualls.net). The program simply records the distances measured by the ultrasonic sensor attached to my Mindstorms 2.0 brick.
My problem is I don't know how to read the Ultrasonic Sensor and the only code I can find on the internet crashes the program without an error.
At the moment I have successfully connected to the NXT with the code below,
Global Variables
If the function returns true, my current code sets up the ultrasonic sensor,
When the Ultrasonic Sensor polls, the following sub routine fires
However, the program crashes without an error when it runs
What am I doing wrong?
Thanks,
JamesStewy
Global Variables
Dim brick As NxtBrick
Dim Sensor_Ultrasonic As New NxtUltrasonicSensorCode: Select all
Function Connect(port As Integer) As Boolean
    Dim COMPortName As String
    COMPortName = "COM" & port
    Try
        brick = New NxtBrick(COMPortName)
        brick.Connect()
        If brick.IsConnected Then
            Return True
        Else
            Return False
        End If
    Catch ex As Exception
        Return False
        MsgBox("Error: " & ex.Message)
        Label_Status.Text = "Error"
    End Try
End FunctionCode: Select all
brick.Sensor1 = Sensor_Ultrasonic
AddHandler Sensor_Ultrasonic.OnPolled, AddressOf Sensor_Ultrasonic_OnPolled
Sensor_Ultrasonic.PollInterval = 100Code: Select all
Sub Sensor_Ultrasonic_OnPolled(ByVal polledItem As NxtPollable)
    Dim sensor As NxtUltrasonicSensor = polledItem
    [b]Dim Distance As Single = sensor.DistanceCm[/b]
    Label1.Text = Distance.ToString
End SubCode: Select all
Dim Distance As Single = sensor.DistanceCmThanks,
JamesStewy
