RCX NQC variable types
Posted: 28 Oct 2010, 02:58
What different types of variables are available in NQC? I know "int" is, but that seems to be the only one. Is it?
Re: RCX NQC variable types
Posted: 28 Oct 2010, 15:04
by afanofosc
The RCX firmware supports only one variable type so NQC only gives you one type. 16 bit signed integers using the "int" keyword. You do have access also to arrays of int and int pointers if you use the RCX 2.0 firmware and the latest NQC compiler.
Posted: 31 Oct 2010, 00:23
Ok, that is what I suspected. Thanks. What are int pointers?
Posted: 31 Oct 2010, 07:16
by mightor
Int pointers are pointers to ints
Basically, instead of a memory location holding a value like "100", it holds the value of a memory location of another variable. Everything you wanted to know about pointers but were afraid to ask:
http://pw1.netcom.com/~tjensen/ptr/pointers.htm
Posted: 31 Oct 2010, 16:04
Ok, I think I understand now. Thanks.
Posted: 31 Oct 2010, 17:13
by mightor
Pointers are an awesome way of messing up your program in fantastic and unpredictable ways that are almost impossible to debug.
Posted: 31 Oct 2010, 19:00
LOL. I can see that in theory, that could be very true.
