NTX brick issues
Posted: 17 Sep 2012, 20:11
I have recently purchased NXT 2.0. Unfortunately, I have faced few major issues with the NXT brick:
1. I noticed that it is not possible to set degrees or rotations while using the servo motors. They do not stop. However, it is not a problem to set durations in seconds. These commands being successfully executed.
2. The "Try Me" programs do not give any results except the touch sensor. The ultrasonic one doesn't give any result. It is the same with motors, regardless if IÂ check degrees or rotations.
I haven't tested the light sensor yet.
Please provide me with detailed instructions how to test all the sensors and motors in order to make sure that they are properly operating. I have tried to change the firmware to 1.26, 1.29 and 1.31. This haven't solved these problems.
Looking forward to hearing from you.
