SOLVED: BricxCC Compilation Error, line 1 file "Files"...
Posted: 07 Sep 2012, 21:46
by jld001
This is the Error:
line 1, file "Files": Error: Unable to find the specified input file
Windows 7, BricxCC 3.3, NXC.
My first line is a comment. Any ideas? Thanks in advance!
Re: BricxCC Compilation Error, line 1 file "Files"...
Posted: 08 Sep 2012, 08:23
what a pity! I just lent my soothsayer's crystal ball to somebody else :(
so all I can assume is that the compiler is probably unable to find the specified input file "Files" in line 1 of your source code
Posted: 08 Sep 2012, 11:49
by h-g-t
Perhaps you could post the actual line of code?
Posted: 08 Sep 2012, 14:08
by jld001
Thanks for the concern.
The problem is that I had a path in the EXE Path in the settings. Maybe something to do with the path having the word "Files" in it. I deleted the line, and it works fine now.
(Edit>Preferences>Compiler>NBC/NXC>EXE path)
Re: SOLVED: BricxCC Compilation Error, line 1 file "Files"...
Posted: 08 Sep 2012, 15:49
well, my crystal ball prognosticates that your first code line actually could have been no comment. ;)
Posted: 12 Sep 2012, 06:55
by afanofosc
You can grab a new test release from
This latest test release includes changes to fix this bug. You should now be able to have an EXE Path containing spaces configured in the Preferences dialog for the NBC/NXC compiler without causing compiler errors. Of course, if you use the external compiler then this path must be a valid path to the nbc.exe executable.
