issues with nxt-g ide
Posted: 23 May 2012, 16:26
by walduss
I have receive my mindstorm kit one week ago. I am trying to learn nxt-g during this week but I have found some dificulties.
1st, I dont really know how delete a wire.
2nd, some times I get an error. "There is a data wire that does not have a data source."
but I dont find it. I delete some blocks one by one until error disapears, and later repeat all the job....... this is not a good solution.
3nd, sometimes when I copy /paste a group of block, a beam appears in the middle os screen (this bean is not connected to any other beam. I dont know how delete it.
I have the release v2.0.f4. is this the last one???
note I am usin Win7 64bits
I want to use nxt-g, because I am teaching my daughter, so, could you hlp me? .......any information is wellcome.
thanks in advance.
Re: issues with nxt-g ide
Posted: 23 May 2012, 18:12
by inxt-generation
NXT-G is really buggy, so expect errors.
1. To delete a wire, simply select it, and press the "delete" button on your keyboard.
2. This is probably caused by having a wire go into a block, but without plugging into a output. I'm not sure what to do about that. This tool might help. The instructions to install it are here.
3.This is one of the bugs I was talking about. AFAIK, there's no way around this. Just try to go slow and let the editor catch up.
NXT-G is good for beginners, but as you get more experienced you will quickly hit the limits of what it can do.
Posted: 23 May 2012, 19:05
by h-g-t
I struggled on with NXT-G because I thought the alternatives were too complicated.
Very surprised to find that NXC was actually simpler to use, as well as more powerful and easier to modify!
Posted: 23 May 2012, 20:41
by walduss
Thanks for your comments..
inxt-generation wrote:NXT-G is really buggy, so expect errors.
1. It was the first thing that I did, but I had no success. Perhaps it is because it is not clear when the wired is selected.
2. I will check RemoveBadWires tool. For sure this tool must be included in the original software.
3. I will look for more info about this bug in this forum. Thanks
h-g-t wrote:I struggled on with NXT-G because I thought the alternatives were too complicated.
By the time been I want to learn nxt-g to teach my daugther, ... But In the future I will try other languages perhaps NXC will be the next one.
Thanks
Posted: 24 May 2012, 00:37
by h-g-t
Posted: 24 May 2012, 13:04
by hassenplug
If you click on a block's drawer INPUT that has a wire connected to it, the wire will be deleted.
Using the mouse, you can create a box around a wire or a beam (that gets left after pasting blocks). That will select the wire/beam. Then, you can just hit delete.
To create the box, just click and drag the mouse. You should see the box appear as you drag. It will select everything that is even partially in the box. That means if you select part of a block and hit delete, it will delete the block.
Tip: you can also use the mouse-drag to scroll the screen, but dragging the mouse to the edge of the screen...
Posted: 24 May 2012, 16:15
by walduss
hassenplug wrote:If you click on a block's drawer INPUT that has a wire connected to it, the wire will be deleted.
Good tips. Today it has been easier workng with the NXT-G environtment. These tips help me a lot.
Thanks
