[NXC]Questions from a newbie :-)
jojoguy14
Post by jojoguy14 »
Hello people!
I' starting to learn NXC (slowly!) I have John Hansen's book and I've been using it as a reference.
I'm an NXT-G guy. I LOVE graphical programming languages :) . So, I've started "copying" the NXT-G Robot Center programs to NXC. I'm on the ShooterBot with the Color Sensor program (but, I'm using a light sensor in my program).
1. I need help (in general) how to setup a sensor and using/reading from it.
2. How to use a While loop to control when I want the program to stop.
Here's the code (MUCH easier pasting NXC code than NXT-G code, lol! :) )
task main() {
  SetSensorType(S3, SENSOR_TYPE_LIGHT_INACTIVE);
  SetSensorMode(S3, SENSOR_MODE_PERCENT);
    while (ButtonState(BTNCENTER) = false) {
    if (Sensor(S3) < 50) {
      RotateMotor(OUT_B, 75, 954);
      RotateMotor(OUT_C, 75, -954);
      RotateMotor(OUT_BC, 75, 1440);
    } else {
    OnFwd(OUT_BC, 50);
I hope you can help me out!
Joey "jojoguy10"
Known as jojoguy10
Re: [NXC]Questions from a newbie :-)
This compiles:
task main() {
    while (ButtonState(BTNCENTER) == false) {        // For comparison use == and not =
    else {
      OnFwd(OUT_BC, 50);
When you're comparing values, you need to use 2 equals signs, instead of one.
jojoguy14
Post by jojoguy14 »
Thanks a bunch!
Another question:
How do I make a point turn in NXC (both motors move in opposite directions at the same time)?
Known as jojoguy10
Like this?
OnFwd(OUT_B, 100);
OnRev(OUT_C, 100);
jojoguy14
Post by jojoguy14 »
mattallen37 wrote:Like this?
OnFwd(OUT_B, 100);
OnRev(OUT_C, 100);
Yes, but how do you do that for a certain amount of degrees?
Known as jojoguy10
For absolute position control, I usually use the APR functions that are FW implemented. I don't think I have ever really used RotateMotor before, so I'm not exactly sure how it works.
jojoguy14
Post by jojoguy14 »
h-g-t wrote:You need to use rotate motor - RotateMotor(OUT_AC, 50,360 );
See http://css.engineering.uiowa.edu/~cie/L ... torial.pdf
and http://bricxcc.sourceforge.net/nbc/nxcdoc/NXC_Guide.pdf
Well....thanks, but that didn't help with turning the motors in OPPOSITE directions. But, thanks to you, I looked it up and found something similar: RotateMotorEx. With that, I can define the "turnpct" :-). I set that to 100% and it worked like a charm!
Thanks!
Known as jojoguy10
