Losing Bluetooth link
Posted: 18 Feb 2012, 22:39
by mcsummation
Is it possible to have BricxCC periodically check the Bluetooth link to make sure it is still up? When I try to download a program over BT and the NXT has powered off, it takes a long time before BricxCC gives up and lets me have control back.
Re: Losing Bluetooth link
Posted: 22 Feb 2012, 00:08
by afanofosc
Are you using the internal compiler option in BricxCC? If not you definitely should switch to using it if you connect via Bluetooth.
I will see what I can do to make this work better.
Posted: 22 Feb 2012, 00:25
by mcsummation
Yes, I'm using the internal compiler.
