Win 7 PC freezes on Find Brick (RCX2)
Posted: 09 Dec 2011, 16:17
by foamcleaver
Hi everyone
If I start amending a program before connecting to the RCX and then take the Find Brick option from the tools menu the program ceases to respond. Even Task Manager cannot delete the process - generally I can reboot which is irritating - once I had to unplug the power cable and pull the battery (which is worse than irritating). Any ideas?
Re: Win 7 PC freezes on Find Brick (RCX2)
Posted: 09 Dec 2011, 16:50
by inxt-generation
Do you have 32-bit or 64-bit system?
Posted: 09 Dec 2011, 18:24
by foamcleaver
Sorry - I should have said - its 32 bit. Thanks for your reply.
Posted: 09 Dec 2011, 18:33
by inxt-generation
Have you tried the latest USB tower driver?
Posted: 09 Dec 2011, 18:42
by foamcleaver
I think so; I'm using the one at http://www.robotc.net/files/rcxdriver.zip. See the thread just below this one in the Hardware forum.
Posted: 09 Dec 2011, 18:51
by inxt-generation
I would try the one I linked to. It is the the one afanofosc (A.K.A. The creator of bricxcc) suggests
Posted: 09 Dec 2011, 19:05
by foamcleaver
Spot on. It fixes the freeze problem as well as the problem in the previous thread. What would I do without you guys - thanks.
