Hi
I'm new to programming and lego mindstorms. I'm trying to write a program to make the robot move forward until it touches the line and then based on the angle it's touched it at position itself to follow the line. Then it stops until it here's a clap and then follows the line until there's another clap.
I've tried writing a program where the robot hits the line and turns left until it touches white again. Then if the turn time was less than the time taken to turn 90 degrees it stops otherwise it goes back on itsef until it touches the white. I tried running the program but the robot either just stops at the line or keeps going.
Does anyone have a better suggestion for the angle part or would be interested in looking at my code?
I'm thinking of geting the robot to turn left and store a light value and then do the same with the right. It would then compare the values and turn towards the greater one
Thanks a lot
okami
Help with a line following program
Re: Help with a line following program
Yes, please post your code.
okami-ninja
I'm using bricx cc. Here's the code:
I'm going to write a different version that uses the second idea for finding the angle.
Thanks
#define Threshold 50 //define all thresholds and constants here
long maxTurn = 1300;
#define SOUND_THRESHOLD 75
#define MIC SENSOR_2
long t0, time;
t0 = CurrentTick();
SetSensorLight(IN_3);
SetSensorType(IN_3, SENSOR_TYPE_LIGHT_ACTIVE);//turns sensor on
SetSensorSound(IN_2);
OnFwd(OUT_BC,45);
until (SENSOR_3<Threshold); //goes forward till hits line
* the next part makes it turn left until it leaves the line
* then it works out how long it took to leave the line and if it took
* longer than when it turns 90 degrees it goes back on itself as we want it
* to turn right in that circumstance
OnFwd(OUT_B,45);
OnRev(OUT_C,45);
until (SENSOR_3>Threshold);
time = CurrentTick()-t0;
if(time>=maxTurn){
OnFwd(OUT_C,45); Wait(time);
OnFwd(OUT_C,45);
until(SENSOR_3>Threshold);
until(MIC > SOUND_THRESHOLD ); //hears clap and then follows line
Wait(100);
while(MIC < SOUND_THRESHOLD)
OnFwd(OUT_BC,25);
if (SENSOR_3<Threshold){
OnFwd(OUT_C,40);//these make it turn when touches line
OnRev(OUT_B,80);
else if(SENSOR_3>Threshold){
OnFwd(OUT_B,90);
OnRev(OUT_C,40 );
Off(OUT_BC);
Wait(300);
else { //if it turns less than 90 degrees it has turned the right way and so goes straight to tracking
Wait(100);
OnFwd(OUT_BC,25);
OnFwd(OUT_B,40);//these make it turn when touches line
OnRev(OUT_C,80);
OnFwd(OUT_C,90);
OnRev(OUT_B,40 );
Off(OUT_BC);
Wait(300);
Off(OUT_BC); //turns the robot off
Thanks
okami-ninja
I've just finished writing a different version that uses 2 variables to compare the light in different places. Here's the code for the new one
#define Threshold 50 //defines variables for sound and light
int normSpeed = 45; //defines the different speeds used
int fwdSpeed = 90;
int revSpeed = 40;
SetSensorLight(IN_3); //set the two sensors and turn light on to measure reflected light
OnFwd(OUT_BC,normSpeed);
until (SENSOR_3<Threshold);//it stops at the line
/*The next part will find the angle
*The robot turns slightly to the left and stores the light reading as a variable
*It then does the same for the right
*Then it compares the 2 values and turns towards the greater one and stops when touches white
OnFwd(OUT_B,normSpeed); Wait(100);
int lightLeft=SENSOR_3;
OnFwd(OUT_C,normSpeed); Wait(100);
int lightRight=SENSOR_3;
//the comparison
if(lightLeft>lightRight) //it's lighter on the left so it turns that way
OnFwd(OUT_B,fwdSpeed);
OnRev(OUT_C,revSpeed);
until (SENSOR_3>Threshold);//stops when it leaves the line
until (MIC > SOUND_THRESHOLD); //hears clap and then follows line
Wait(100);
while(MIC < SOUND_THRESHOLD) //tracks until the second clap
OnFwd(OUT_BC,25);
OnFwd(OUT_C,fwdSpeed);
OnRev(OUT_B,revSpeed);
Off(OUT_BC); //stops at 2nd clap
else if(lightLeft<lightRight) //this is for when it should turn right
Wait(100);
OnFwd(OUT_BC,25);
else if(SENSOR_3<Threshold);
Off(OUT_BC);
Could you please use code tags as well so it keeps white-space?[/code]
[code]Matt
okami-ninja
Sorry, I didn't realise you could do that. Thanks
