Thanks for the info. It'd be great to be able to at least see the size of other files, see my next question:
I have another question about creating files. I'm attempting to create a file of size 4360. When I run it, the program fails. I've included the code below. If I comment out the loop that writes to the file (ie: only CreateFile() and CloseFile() are executed), it creates a file that is zero bytes (at least when I upload to the PC using NXT explorer the resulting PC file is zero btyes). If I leave the write loop in, the program exits with code -1, and a file of 1800 bytes is created (the file_size is correctly computed to be 4360). If I run it with an array shorter than 225 (1800 / 8) it seems to work happily.
Is there a limit on file size? I don't think I'm running out of flash memory because I can run it multiple times with new file names and it keeps creating the new files, all 1800 bytes.
Thanks for any info.
float dec_n23[][] = {
{99.23,30.15},
{99.12,30.36},
{99,30.57},
{98.88,30.77},
{98.76,30.98},
{98.65,31.19},
{98.53,31.39},
{98.41,31.6},
{98.29,31.81},
{98.18,32.02},
{98.06,32.22},
{97.94,32.43},
{97.82,32.64},
{97.7,32.85},
{97.58,33.05},
{97.47,33.26},
{97.35,33.47},
{97.23,33.68},
{97.11,33.88},
{96.99,34.09},
{96.87,34.3},
{96.75,34.51},
{96.63,34.71},
{96.51,34.92},
{96.39,35.13},
{96.27,35.34},
{96.15,35.55},
{96.03,35.76},
{95.91,35.96},
{95.79,36.17},
{95.67,36.38},
{95.54,36.59},
{95.42,36.8},
{95.3,37.01},
{95.18,37.21},
{95.06,37.42},
{94.93,37.63},
{94.81,37.84},
{94.69,38.05},
{94.56,38.26},
{94.44,38.47},
{94.32,38.67},
{94.19,38.88},
{94.07,39.09},
{93.94,39.3},
{93.82,39.51},
{93.69,39.72},
{93.57,39.93},
{93.44,40.14},
{93.31,40.35},
{93.19,40.55},
{93.06,40.76},
{92.93,40.97},
{92.81,41.18},
{92.68,41.39},
{92.55,41.6},
{92.42,41.81},
{92.29,42.02},
{92.16,42.23},
{92.03,42.44},
{91.9,42.65},
{91.77,42.86},
{91.64,43.06},
{91.51,43.27},
{91.38,43.48},
{91.25,43.69},
{91.12,43.9},
{90.98,44.11},
{90.85,44.32},
{90.72,44.53},
{90.58,44.74},
{90.45,44.95},
{90.31,45.16},
{90.18,45.37},
{90.04,45.58},
{89.9,45.79},
{89.77,46},
{89.63,46.2},
{89.49,46.41},
{89.35,46.62},
{89.21,46.83},
{89.07,47.04},
{88.93,47.25},
{88.79,47.46},
{88.65,47.67},
{88.5,47.88},
{88.36,48.09},
{88.22,48.3},
{88.07,48.51},
{87.93,48.72},
{87.78,48.93},
{87.64,49.13},
{87.49,49.34},
{87.34,49.55},
{87.19,49.76},
{87.05,49.97},
{86.9,50.18},
{86.74,50.39},
{86.59,50.6},
{86.44,50.81},
{86.29,51.02},
{86.13,51.22},
{85.98,51.43},
{85.82,51.64},
{85.67,51.85},
{85.51,52.06},
{85.35,52.27},
{85.19,52.48},
{85.03,52.69},
{84.87,52.89},
{84.71,53.1},
{84.55,53.31},
{84.38,53.52},
{84.22,53.73},
{84.05,53.94},
{83.89,54.14},
{83.72,54.35},
{83.55,54.56},
{83.38,54.77},
{83.21,54.98},
{83.04,55.18},
{82.86,55.39},
{82.69,55.6},
{82.51,55.81},
{82.33,56.02},
{82.15,56.22},
{81.97,56.43},
{81.79,56.64},
{81.61,56.84},
{81.43,57.05},
{81.24,57.26},
{81.05,57.47},
{80.87,57.67},
{80.68,57.88},
{80.48,58.09},
{80.29,58.29},
{80.1,58.5},
{79.9,58.7},
{79.7,58.91},
{79.5,59.12},
{79.3,59.32},
{79.1,59.53},
{78.89,59.73},
{78.69,59.94},
{78.48,60.14},
{78.27,60.35},
{78.06,60.55},
{77.84,60.76},
{77.62,60.96},
{77.41,61.17},
{77.19,61.37},
{76.96,61.58},
{76.74,61.78},
{76.51,61.98},
{76.28,62.19},
{76.05,62.39},
{75.81,62.59},
{75.58,62.8},
{75.34,63},
{75.1,63.2},
{74.85,63.4},
{74.6,63.61},
{74.35,63.81},
{74.1,64.01},
{73.85,64.21},
{73.59,64.41},
{73.33,64.61},
{73.06,64.81},
{72.79,65.01},
{72.52,65.21},
{72.25,65.41},
{71.97,65.61},
{71.69,65.81},
{71.4,66.01},
{71.11,66.21},
{70.82,66.4},
{70.53,66.6},
{70.23,66.8},
{69.92,67},
{69.61,67.19},
{69.3,67.39},
{68.99,67.58},
{68.67,67.78},
{68.34,67.97},
{68.01,68.17},
{67.68,68.36},
{67.34,68.56},
{66.99,68.75},
{66.64,68.94},
{66.29,69.13},
{65.93,69.32},
{65.56,69.52},
{65.19,69.71},
{64.81,69.9},
{64.43,70.08},
{64.04,70.27},
{63.65,70.46},
{63.24,70.65},
{62.83,70.83},
{62.42,71.02},
{62,71.21},
{61.57,71.39},
{61.13,71.57},
{60.69,71.76},
{60.24,71.94},
{59.78,72.12},
{59.31,72.3},
{58.84,72.48},
{58.35,72.66},
{57.86,72.84},
{57.36,73.01},
{56.85,73.19},
{56.33,73.36},
{55.79,73.54},
{55.25,73.71},
{54.7,73.88},
{54.14,74.05},
{53.57,74.22},
{52.99,74.39},
{52.4,74.56},
{51.79,74.72},
{51.18,74.88},
{50.55,75.05},
{49.91,75.21},
{49.25,75.37},
{48.59,75.53},
{47.91,75.68},
{47.21,75.84},
{46.51,75.99},
{45.79,76.14},
{45.05,76.29},
{44.3,76.44},
{43.53,76.58},
{42.75,76.72},
{41.96,76.87},
{41.15,77},
{40.32,77.14},
{39.47,77.28},
{38.61,77.41},
{37.74,77.54},
{36.84,77.66},
{35.93,77.79},
{35,77.91},
{34.06,78.03},
{33.09,78.14},
{32.11,78.26},
{31.11,78.37},
{30.1,78.47},
{29.06,78.58},
{28.01,78.68},
{26.95,78.77},
{25.86,78.87},
{24.76,78.96},
{23.64,79.04},
{22.5,79.12},
{21.35,79.2},
{20.19,79.28},
{19,79.35},
{17.81,79.41},
{16.6,79.47},
{15.38,79.53},
{14.14,79.58},
{12.89,79.63},
{11.64,79.68},
{10.37,79.72},
{9.09,79.75},
{7.81,79.78},
{6.52,79.81},
{5.22,79.83},
{3.92,79.85},
{2.61,79.86},
{1.31,79.87},
{0,79.87},
{-1.31,79.87},
{-2.61,79.86},
{-3.92,79.85},
{-5.22,79.83},
{-6.52,79.81},
{-7.81,79.78},
{-9.09,79.75},
{-10.37,79.72},
{-11.64,79.68},
{-12.89,79.63},
{-14.14,79.58},
{-15.38,79.53},
{-16.6,79.47},
{-17.81,79.41},
{-19,79.35},
{-20.19,79.28},
{-21.35,79.2},
{-22.5,79.12},
{-23.64,79.04},
{-24.76,78.96},
{-25.86,78.87},
{-26.95,78.77},
{-28.01,78.68},
{-29.06,78.58},
{-30.1,78.47},
{-31.11,78.37},
{-32.11,78.26},
{-33.09,78.14},
{-34.06,78.03},
{-35,77.91},
{-35.93,77.79},
{-36.84,77.66},
{-37.74,77.54},
{-38.61,77.41},
{-39.47,77.28},
{-40.32,77.14},
{-41.15,77},
{-41.96,76.87},
{-42.75,76.72},
{-43.53,76.58},
{-44.3,76.44},
{-45.05,76.29},
{-45.79,76.14},
{-46.51,75.99},
{-47.21,75.84},
{-47.91,75.68},
{-48.59,75.53},
{-49.25,75.37},
{-49.91,75.21},
{-50.55,75.05},
{-51.18,74.88},
{-51.79,74.72},
{-52.4,74.56},
{-52.99,74.39},
{-53.57,74.22},
{-54.14,74.05},
{-54.7,73.88},
{-55.25,73.71},
{-55.79,73.54},
{-56.33,73.36},
{-56.85,73.19},
{-57.36,73.01},
{-57.86,72.84},
{-58.35,72.66},
{-58.84,72.48},
{-59.31,72.3},
{-59.78,72.12},
{-60.24,71.94},
{-60.69,71.76},
{-61.13,71.57},
{-61.57,71.39},
{-62,71.21},
{-62.42,71.02},
{-62.83,70.83},
{-63.24,70.65},
{-63.65,70.46},
{-64.04,70.27},
{-64.43,70.08},
{-64.81,69.9},
{-65.19,69.71},
{-65.56,69.52},
{-65.93,69.32},
{-66.29,69.13},
{-66.64,68.94},
{-66.99,68.75},
{-67.34,68.56},
{-67.68,68.36},
{-68.01,68.17},
{-68.34,67.97},
{-68.67,67.78},
{-68.99,67.58},
{-69.3,67.39},
{-69.61,67.19},
{-69.92,67},
{-70.23,66.8},
{-70.53,66.6},
{-70.82,66.4},
{-71.11,66.21},
{-71.4,66.01},
{-71.69,65.81},
{-71.97,65.61},
{-72.25,65.41},
{-72.52,65.21},
{-72.79,65.01},
{-73.06,64.81},
{-73.33,64.61},
{-73.59,64.41},
{-73.85,64.21},
{-74.1,64.01},
{-74.35,63.81},
{-74.6,63.61},
{-74.85,63.4},
{-75.1,63.2},
{-75.34,63},
{-75.58,62.8},
{-75.81,62.59},
{-76.05,62.39},
{-76.28,62.19},
{-76.51,61.98},
{-76.74,61.78},
{-76.96,61.58},
{-77.19,61.37},
{-77.41,61.17},
{-77.62,60.96},
{-77.84,60.76},
{-78.06,60.55},
{-78.27,60.35},
{-78.48,60.14},
{-78.69,59.94},
{-78.89,59.73},
{-79.1,59.53},
{-79.3,59.32},
{-79.5,59.12},
{-79.7,58.91},
{-79.9,58.7},
{-80.1,58.5},
{-80.29,58.29},
{-80.48,58.09},
{-80.68,57.88},
{-80.87,57.67},
{-81.05,57.47},
{-81.24,57.26},
{-81.43,57.05},
{-81.61,56.84},
{-81.79,56.64},
{-81.97,56.43},
{-82.15,56.22},
{-82.33,56.02},
{-82.51,55.81},
{-82.69,55.6},
{-82.86,55.39},
{-83.04,55.18},
{-83.21,54.98},
{-83.38,54.77},
{-83.55,54.56},
{-83.72,54.35},
{-83.89,54.14},
{-84.05,53.94},
{-84.22,53.73},
{-84.38,53.52},
{-84.55,53.31},
{-84.71,53.1},
{-84.87,52.89},
{-85.03,52.69},
{-85.19,52.48},
{-85.35,52.27},
{-85.51,52.06},
{-85.67,51.85},
{-85.82,51.64},
{-85.98,51.43},
{-86.13,51.22},
{-86.29,51.02},
{-86.44,50.81},
{-86.59,50.6},
{-86.74,50.39},
{-86.9,50.18},
{-87.05,49.97},
{-87.19,49.76},
{-87.34,49.55},
{-87.49,49.34},
{-87.64,49.13},
{-87.78,48.93},
{-87.93,48.72},
{-88.07,48.51},
{-88.22,48.3},
{-88.36,48.09},
{-88.5,47.88},
{-88.65,47.67},
{-88.79,47.46},
{-88.93,47.25},
{-89.07,47.04},
{-89.21,46.83},
{-89.35,46.62},
{-89.49,46.41},
{-89.63,46.2},
{-89.77,46},
{-89.9,45.79},
{-90.04,45.58},
{-90.18,45.37},
{-90.31,45.16},
{-90.45,44.95},
{-90.58,44.74},
{-90.72,44.53},
{-90.85,44.32},
{-90.98,44.11},
{-91.12,43.9},
{-91.25,43.69},
{-91.38,43.48},
{-91.51,43.27},
{-91.64,43.06},
{-91.77,42.86},
{-91.9,42.65},
{-92.03,42.44},
{-92.16,42.23},
{-92.29,42.02},
{-92.42,41.81},
{-92.55,41.6},
{-92.68,41.39},
{-92.81,41.18},
{-92.93,40.97},
{-93.06,40.76},
{-93.19,40.55},
{-93.31,40.35},
{-93.44,40.14},
{-93.57,39.93},
{-93.69,39.72},
{-93.82,39.51},
{-93.94,39.3},
{-94.07,39.09},
{-94.19,38.88},
{-94.32,38.67},
{-94.44,38.47},
{-94.56,38.26},
{-94.69,38.05},
{-94.81,37.84},
{-94.93,37.63},
{-95.06,37.42},
{-95.18,37.21},
{-95.3,37.01},
{-95.42,36.8},
{-95.54,36.59},
{-95.67,36.38},
{-95.79,36.17},
{-95.91,35.96},
{-96.03,35.76},
{-96.15,35.55},
{-96.27,35.34},
{-96.39,35.13},
{-96.51,34.92},
{-96.63,34.71},
{-96.75,34.51},
{-96.87,34.3},
{-96.99,34.09},
{-97.11,33.88},
{-97.23,33.68},
{-97.35,33.47},
{-97.47,33.26},
{-97.58,33.05},
{-97.7,32.85},
{-97.82,32.64},
{-97.94,32.43},
{-98.06,32.22},
{-98.18,32.02},
{-98.29,31.81},
{-98.41,31.6},
{-98.53,31.39},
{-98.65,31.19},
{-98.76,30.98},
{-98.88,30.77},
{-99,30.57},
{-99.12,30.36},
{-99.23,30.15},
