Having trouble getting two bricks to talk via bluetooth...
Posted: 22 Oct 2011, 23:47
Hello! I've only recently started working with NXT robots and I'm having a bit of trouble.
I want my two bricks to talk to each other - just to send information. I wrote a simple test program in which one sends the other a message and the second one signals that it has received it. But I can't even get to the point of testing it because they fail to connect at all.
All the instructions I've seen say something like: make sure both have bluetooth on and are set to visible, go into 'search' and, when it is done, select 'NXT' and then '1'. It will say connecting, then ask for a pass code on both machines.
But the last thing doesn't happen, it just says 'failed.' Could somebody please tell me what I'm doing wrong?
