Constants and Data wires
Posted: 21 Oct 2011, 19:07
by ivanovonavich
I'm fairly new to NXT 2.1. I'm coaching a team with our first event scheduled for Dec. In any case, I'm trying to stay one step ahead of the kids....
My problem is this:
We will be operating our NXT in an environment with a significantly different light setting than where we practice. Our solution, when using the light sensor, is to simply use "Constants" to set the min and max range to sense the white and dark lines on the Field Set Up board.
We have had great success in using constants controlling the "Power" of the "Move" blocks in association with the ultra sonic sensor.
However, we have difficultly with the light sensor set up. We have a logic controlled loop where we have inside, a constant block, a light sensor block and a timer; in that order. A wire is connected from the constant block on the "Value" port to the "Trigger Point" port on the light sensor in our desire that the sensor will use that constant to compare the value listed in the "Constant" verses what defaults into the window on the the light sensor. Then, a green logical YES/NO wire leaves the light sensor block to the loop controlled again by the YES/NO.
It doesn't seem to work. I don't know yet of a way to confirm the data values a sensor is looking at; namely, is my light sensor using the constant value input, or is it using the value in the box listed next to the slider?
Any thoughts anyone?
Ivan
Re: Constants and Data wires
Posted: 22 Oct 2011, 00:35
by muntoo
I re-posted here since it not really a software question....the forum where I initially placed it.
My problem is this:
Ivan
Anything connected by a datawire should override what it says in the block's "properties".
Can you post a picture and a program? (The program should be in a .7z file, for max compression. Then, you'll need to .zip it, so you can upload it here.)
Posted: 01 Nov 2011, 07:21
by bungeshea
Okay, the first thing is, what do you need the timer block for?
The next thing you could try is removing the consistent block temporarily and entering your light values into the config panel. If it doesn't work, then it is a configuration problem, nothing to do with the consistent.
If you could try to upload a picture (screenshot) or your actual program, that would really help.
