Touch sensor problem - High resistance with opened switches
Posted: 16 Sep 2011, 02:51
The topic may be simplistic. In my newer vending machine creation, I have the following scenario:
Some things are hard to understand why the h*ll did I need to do that way... The machine can be seen here: http://www.youtube.com/watch?v=WUItzPTetpc
The 9V end on the right is for the coin conductivity detection. It has one extra old electric plate, but I think it doesn't matter that much to evaluate the problem.
I know I'm pushing a little bit the limits, but I'd like to know your idea of what can be the weakest point in the layout, that may be producing high resistance value on the input (around 400 or more). The value also oscilates sometimes...
Assume that the custom NXT-NXT connectors are correctly built. I'm pretty sure they are... I'm using a PCB and mindsensors sockets.
I'm using mindsensors enhanced firmware, for longer wiring connections (which I believe to only help for the I2C connections).
Ricardo
Ricardo
