[NXC][Bug] Different type comparisons
// #define min(a,b) ((a) < (b) ? (a) : (b))
// #include "minmax.nxc"
	unsigned int ui = 441;
	long l = 64;
	// unsigned int len = min(l, ui);
	unsigned int len = l < ui ? l : ui;
	NumOut(0, 0, len, 1);
	Wait(1000);
Displays 441, not 64! This bug was torturing me in NXTFileManager. :)
linusa
Re: [NXC][Bug] Different type comparisons
Post by linusa »
Hmm, isn't that more of C a "feature"? I know I always get a warning in Visual C++ (highest warning level) when comparing signed with unsigned types. I could imagine it's because of binary representation...
Try it with casting, two versions. Either:
unsigned int len = (unsigned int) (l < ui) ? l : ui;
or, the extreme careful "correct" version:
unsigned int len = (unsigned int) ((unsigned int) l < ui) ? l : ui;
Edited typos
NXC doesn't support C-like type casting. :( (I put it on the wishlist a few months ago, IIRC.)
Besides, NXC should implicitly convert them, especially in a simple case such as this.
Output NBC code:
	set ui, 441
	set l, 64
	mov __signed_stack_001main, __constVal64
	mov __DU0main, ui
	cmp 0, __zfmain, __signed_stack_001main, __DU0main
	mov __D0main, __zfmain
	brtst 4, __NXC_Label_610, __zfmain
	mov __D0main, l
	jmp __NXC_Label_611
__NXC_Label_610:
	mov __DU0main, ui
__NXC_Label_611:
	mov len, __DU0main
linusa
Post by linusa »
muntoo wrote: Besides, NXC should implicitly convert them, especially in a simple case such as this.
That's exactly the root of the problem I imagine: How would you convert?
When you have a large unsigned int (let's say 2^32-1), you can't convert it to a signed one! On the other hand, when you've got a negative signed int, how would you convert that to unsigned?
So you need some kind of logic, just by auto-casting it won't work. And I guess this logic is not built into NXC (yet). So it's a binary compare. Which makes sense, performance-wise. And then you've got strange things happening all over (one point might be http://en.wikipedia.org/wiki/Signed_num ... sentations ).
the solution is - also according to my own wish on the wish list some months ago - :
explicite type casting like in ANSI C.
long l;
unsigned int ui;
float f;
f=(float)ui;
l=(long)ui;
You can manually cast like this:
unsigned int ui = 42;
float ui2 = ui;
I'm not sure if it casts correctly in all cases though. I will do some testing.
yes, I'm already using this workaround temporarily, it works AFAIK, but again leads to spaghetti code -
so real-C-type-casting is appreciated anyway!
(I actually hate spaghetti code)
linusa
Post by linusa »
doc-helmut wrote:yes, I'm already using this workaround temporarily, it works AFAIK, but again leads to spaghetti code -
I don't see the spaghetti code:
long l;
unsigned int ui;
float f;
f=floatFromUI(ui);
l=longFromUI(ui);
with
inline float floatFromUI(const unsigned int ui) {
   float f = ui;
   return f;
inline long longFromUI(const unsigned int ui) {
   long l = ui;
   return l;
Yes, its annoying because of missing function overloading, and yes, NXC should have casting functions. But those aren't excuses for spaghetti :-)
...will probably not work in cases of macros like
unsigned int ui;
printf("%e", (float)ui);
# Error: constant or constant expression expected
File "c:\Temp\temp.nxc" ; line 15
# string msg = FormatNum("%e", floatFromUI(ui))
(CMIIW)
linusa
Post by linusa »
doc-helmut wrote:...will probably not work in cases like
Yep, tried
unsigned int ui;
printf("%e", floatFrom(ui));
, fails with good old "constant expression expected". So I guess this problem would probably also occur with
, depending on how typcasts would be implemented in NXC.
Users browsing this forum: Semrush [Bot] and 35 guests
