Re: BricxCC/NBC test release 2011-07-19
Posted: 25 Oct 2011, 06:52
test with new release 2011-10-25:
// level 0: 8780
// level 1: 7861
// level 2: file error -1
// level 3: file error -1
// level 4: file error -1
still stable is old release 2010702! (see above)
// new release 2011-10-25:doc-helmut wrote:Matrix test, jch version:Code: Select all
// Matrix algebra / arithmetics // vers. 0.92t (HaWe+jch+splrc version) #define MatrixMulS(_Out, _A, _s) asm { mul _Out, _A, _s } #define MatrixDivS(_Out, _A, _s) asm { div _Out, _A, _s } #define MatrixAdd(_Out, _A, _B) asm { add _Out, _A, _B } #define MatrixSub(_Out, _A, _B) asm { sub _Out, _A, _B } #define ArrayIndex(_out, _A, _i) asm { index _out, _A, _i } #define ArrayReplace(_A, _i, _new) asm { replace _A, _A, _i, _new } #define BranchTest(_cmp, _lbl, _v1) asm{ brtst _cmp, _lbl, _v1 } #define BranchComp(_cmp, _lbl, _v1, _v2) asm{ brcmp _cmp, _lbl, _v1, _v2 } #define ArrayInit2D(array, tmp, init_val, dimx, dimy) { \ ArrayInit(tmp, init_val, dimy); \ ArrayInit(array, tmp, dimx); \ ArrayInit(tmp,0,0); \ } void MatrixTransp(float A[][], float &C[][], int R, int S) { float tmp[], arr_temp[], val_temp; int s, r; ArrayInit(tmp, 0, R); ArrayInit(C, tmp, S); s = S; lbl_Trans_start_s: { s--; r = R; lbl_Trans_start_r: { r--; ArrayIndex(arr_temp, A, r); ArrayIndex(val_temp, arr_temp, s); ArrayReplace(tmp, r, val_temp); } BranchTest(GT, lbl_Trans_start_r, r); ArrayReplace(C, s, tmp); } BranchTest(GT, lbl_Trans_start_s, s); } // N x M Matrix * M x K Matrix, OLD version void MatrixMatrixMult_OLD(float A[][], float B[][], float &C[][], int N, int M, int K){ int i, j, s; for (i=0; i<N; ++i) { for (j=0; j<K; ++j) { C[i][j]=0; for (s=0; s<M; ++s) { C[i][j]=C[i][j] + A[i][s]*B[s][j]; } } } } // N x M Matrix * M x K Matrix, NEW version void MatrixMatrixMult(float A[][], float B[][], float &C[][], int N, int M, int K){ float arr_temp[]; //Set size of C ArrayInit( arr_temp, 0, K ); ArrayInit( C, arr_temp, N ); lbl_Mult_start_i: N--; //Loop start //Speed up arrays float A_i[]; float C_i[]; ArrayIndex(A_i, A, N); ArrayIndex(C_i, C, N); int j = K; lbl_Mult_start_j: j--; //Second loop start float sum = 0; int s = M; lbl_Mult_start_s: s--; //Third loop start //sum += A_i[s]*B[s][j]; float temp, sum_temp; ArrayIndex(sum_temp, A_i, s); ArrayIndex(arr_temp, B, s); ArrayIndex(temp, arr_temp, j); sum_temp *= temp; sum += sum_temp; asm { brtst GT, lbl_Mult_start_s, s } ArrayReplace(C_i, j, sum); asm { brtst GT, lbl_Mult_start_j, j } ArrayReplace(C, N, C_i); asm { brtst GT, lbl_Mult_start_i, N } } void MatrixRotate2DMath(float A[][], float &C[][], float angleDeg) { float tmp[], x, B[][]; ArrayInit2D(C, tmp, 0, 2, 2); x=cosd(angleDeg); ArrayInit2D(B, tmp, x, 2, 2); x=sind(angleDeg); B[0][1]=-x; B[1][0]= x; MatrixMatrixMult(B, A, C, 2, 2, 2); } #define MatrixRotate2DGeo(A,C, d) MatrixRotate2DMath(A,C,-d) float MatrixDet2x2(float A[][]) { // Determinante 1x1, 2x2, 3x3 float r0[], r1[], r2[], v00, v01, v02, v10, v11, v12, v20, v21, v22; r0 = A[0]; r1 = A[1]; return ( r0[0]*r1[1]- r0[1]*r1[0] ); } float MatrixDet3x3(float A[][]) { // Determinante 3x3 float r0[], r1[], r2[], v00, v01, v02, v10, v11, v12, v20, v21, v22; r0 = A[0]; r1 = A[1]; r2 = A[2]; v00 = r0[0]; v01 = r0[1]; v02 = r0[2]; v10 = r1[0]; v11 = r1[1]; v12 = r1[2]; v20 = r2[0]; v21 = r2[1]; v22 = r2[2]; return (v00*v11*v22 +v01*v12*v20 +v02*v10*v21 -v02*v11*v20 -v01*v10*v22 -v00*v12*v21); } void MatrixAdj2x2 (float A[][], float &C[][]) { // Adjugate=Adjunkte 1x1, 2x2, 3x3 float r0[], r1[], r2[], c0[], c1[], c2[], t0, t1, t2; ArrayIndex(r0, A, 0); ArrayIndex(r1, A, 1); ArrayIndex(t0, r1, 1); ArrayIndex(t1, r0, 1); asm { mul t1, t1, -1 } ArrayBuild(c0, t0, t1); ArrayIndex(t0, r1, 0); asm { mul t0, t0, -1 } ArrayIndex(t1, r0, 0); ArrayBuild(c1, t0, t1); ArrayBuild(C, c0, c1); } void MatrixAdj3x3 (float A[][], float &C[][]) { // Adjugate=Adjunkte 1x1, 2x2, 3x3 float r0[], r1[], r2[], c0[], c1[], c2[], t0, t1, t2; float v00, v01, v02, v10, v11, v12, v20, v21, v22; r0 = A[0]; r1 = A[1]; r2 = A[2]; v00 = r0[0]; v01 = r0[1]; v02 = r0[2]; v10 = r1[0]; v11 = r1[1]; v12 = r1[2]; v20 = r2[0]; v21 = r2[1]; v22 = r2[2]; t0 = v11*v22-v12*v21; t1 = v02*v21-v01*v22; t2 = v01*v12-v02*v11; ArrayBuild(c0, t0, t1, t2); t0 = v12*v20-v10*v22; t1 = v00*v22-v02*v20; t2 = v02*v10-v00*v12; ArrayBuild(c1, t0, t1, t2); t0 = v10*v21-v11*v20; t1 = v01*v20-v00*v21; t2 = v00*v11-v01*v10; ArrayBuild(c2, t0, t1, t2); ArrayBuild(C, c0, c1, c2); } bool MatrixInverse2x2(float A[][], float &C[][]) { float det; det=MatrixDet2x2(A); if (det==0) return 0; else { MatrixAdj2x2(A, C); C/=det; return 1; } } bool MatrixInverse3x3(float A[][], float &C[][]) { float det; det=MatrixDet3x3(A); if (det==0) return 0; else { MatrixAdj3x3(A, C); C/=det; return 1; } } void MatrixLinear(float A[][], float &C[], int R, int S) { int i=0, s, r; int dim=R*S; ArrayInit(C, 0, dim); for (s=0; s<S; ++s) { for (r=0; r<R; ++r) { C[i++]=A[r][s]; } } } void SubMatrix(float A[][], float &C[][], int RS, int r, int s) { int i=0, j=0, x=0, y=0, dim_1; float tmp[]; dim_1=RS-1; ArrayInit2D(C, tmp, 0, dim_1, dim_1); for (y=0; y<RS; ++y) { for (x=0; x<RS; ++x) { if ((x!=r)&&(y!=s)) { C[i][j]=A[x][y]; ++i; if (i>=dim_1){ i=0; ++j; } } } } } float MatrixMinor(float A[][], int RS, int r, int s) { float C[][]; SubMatrix(A, C, RS, r, s); if(RS==3) { return MatrixDet2x2(C); } else if(RS==4) { return MatrixDet3x3(C); } } float MatrixCofactor(float A[][], int RS, int r, int s) { float x; return pow(-1, r+s)* MatrixMinor(A, RS, r, s);; } float MatrixDet4x4(float A[][]) { float det=0, x=0; int i, j=0, n0, max0=0, imax0, jmax0=0; for (j=0; j<4; ++j) { // find column with most 0's: jmax0 n0=0; for (i=0; i<4; ++i) { if (A[i][j]==0) ++n0; } if (max0<n0) {max0=n0; jmax0=j;} } for (i=0; i<4; ++i) { // find row with most 0's: imax0 n0=0; for (j=0; j<4; ++j) { if (A[i][j]==0) ++n0; } if (max0<n0) {max0=n0; imax0=i;} } if (jmax0>imax0) { for (i=0; i<4; ++i) { // develop from jmax0 if ( A[i][jmax0]!=0) { // 0*?=0 x=A[i][jmax0]*MatrixCofactor(A, 4, i, jmax0); det+=x; } } //TextOut(72,56,"j"); NumOut(80,56,jmax0); //debug return det; } else { for (j=0; j<4; ++j) { // develop from imax0 if ( A[imax0][j]!=0) { // 0*?=0 x=A[imax0][j]*MatrixCofactor(A, 4, imax0, j); det+=x; } } //TextOut(72,56,"i"); NumOut(80,56,imax0); //debug return det; } } // speed test long time0, runtime; task main() { float A[][], B[][], C[][], x; float O[][], T[][], L[][], tmp[];; int loop; time0=CurrentTick(); for (loop=0; loop<100; ++loop) { ArrayInit2D(A, tmp, 0, 2,2); ArrayInit2D(B, tmp, 0, 2,2); ArrayInit2D(C, tmp, 0, 2,2); ArrayInit2D(O, tmp, 0, 4,4); NumOut(0,56,loop); O[0][0]=0; O[0][1]=0; O[0][2]=8; O[0][3]=22; O[1][0]=1; O[1][1]=5; O[1][2]=9; O[1][3]=13; O[2][0]=2; O[2][1]=6; O[2][2]=10; O[2][3]=14; O[3][0]=3; O[3][1]=7; O[3][2]=22; O[3][3]=15; x=MatrixDet4x4(O); SubMatrix(O,T,4, 2,1); // expanded to A[i][j] x=MatrixDet3x3(T); SubMatrix(T,C,3, 0,1); x=MatrixDet2x2(C); x=MatrixMinor(T, 3, 0,1); x=MatrixCofactor(T, 3, 0,1); A[0][0]=1; A[0][1]=3; A[1][0]=2; A[1][1]=4; x=10; B=A; B*=x; C=A; C+=B; MatrixAdj2x2(A,C); MatrixInverse2x2(A,C); MatrixInverse2x2(A,B); MatrixMatrixMult(A,B,C,2,2,2); A[0][0]=1; A[0][1]=1; A[1][0]=1; A[1][1]=0; MatrixRotate2DGeo(A,B,30); MatrixRotate2DGeo(A,C,90); } runtime=CurrentTick()-time0; TextOut(0,40,"run time"); NumOut (0,32, runtime); TextOut(72,32,"msec"); while(1); }
// old release 2010702:
// level 0: 9784
// level 1: 8462
// level 2: 7385
// level 3: 7385
// level 4: 7383
// new release 20110720:
// level 0: 9715
// level 1: 8470
the same for new fw, removed codeCode: Select all
// level 0: 8780
// level 1: 7861
