wishlist for NXC
nxtboyiii
Re: wishlist for NXC
Post by nxtboyiii »
Ok. Thanks for replying.
when will be released the next NXC/Bricx version, and what kind of things will be new or updated?
nxt-ai
Post by nxt-ai »
Is nxtcom under the control of nxc/nbc? On Linux I have no idea of how to download programs as well as on Windows cmd "shell". I assume others have this problem too.
m-goldberg
Post by m-goldberg »
nxt-ai wrote:Is nxtcom under the control of nxc/nbc? On Linux I have no idea of how to download programs as well as on Windows cmd "shell". I assume others have this problem too.
You don't need nxtcom anymore. The compiler can both download and download and run programs directly when it finishes compiling. Look at the -d and -r compiler switches (execute "nbc -help"). This works on the Mac and I presume it will work on Linux as well.
nxt-ai
Post by nxt-ai »
m-goldberg wrote:You don't need nxtcom anymore. The compiler can both download and download and run programs directly when it finishes compiling. Look at the -d and -r compiler switches (execute "nbc -help"). This works on the Mac and I presume it will work on Linux as well.
Last I tried It did nothing, also the -b flag didn't work and it kept saying it had a compiler error (duh it was already compiled).
Does linux need a fantom driver, as well?
On linux I wrote a lib-usb and bluetooth serial port implementation of the Fantom driver so that nbc can talk to the NXT. On Mac OSX and Windows I just linked to the existing Fantom driver libraries. If -d and so forth are not working correctly on Mac OSX then I have to fix that problem. Can you give me a source file and a command line to try which is not working for you? Are you using the nxt.dat file in ~ to provide the correct connection information along with -S=usb|alias|brick_resource_string ?
m-goldberg
afanofosc wrote:On linux I wrote a lib-usb and bluetooth serial port implementation of the Fantom driver so that nbc can talk to the NXT. On Mac OSX and Windows I just linked to the existing Fantom driver libraries. If -d and so forth are not working correctly on Mac OSX then I have to fix that problem. Can you give me a source file and a command line to try which is not working for you? Are you using the nxt.dat file in ~ to provide the correct connection information along with -S=usb|alias|brick_resource_string ?
The -d and -r switches work fine on OS X. I use them all the time. I think the question is whether they also work on Linux.
Regards, Morton
schodet
Post by schodet »
m-goldberg wrote:The -d and -r switches work fine on OS X. I use them all the time. I think the question is whether they also work on Linux.
They do, I use them all the time.
is there a qsort in NXC or sth similar (insertion sort, even a bubble sort)?
Should be fairly trivial to implement in either NBC or NXC, I would say. It would be really dependant on the types you're looking to sort. A qsort for longs would not work for floats, for example.
