Re: NXT access via USB on OSX
Posted: 04 Jun 2011, 18:23
Code from my FantomSpirit.pas file may be useful in getting your calls to the Fantom API's sendDirectCommand function working when you require a response. Here are a few snippets:
The length you pass into the sendDirectCommand function has to be 1 less than the expected response length. So for example, you expect 64 bytes from MessageRead but you have to pass in 63 or it will not work.
Also see my implementation of iNXT_sendSystemCommand and iNXT_sendDirectCommandEx in FantomSpirit.pas. These both work with USB and Bluetooth and for commands that do not require a response and those that do require a response. There is no reason this code would not work correctly if written equivalently in C/C++ or any other programming language.
The cmd.BytePtr, cmd.Len code in the above snippets simply drops the first byte of the cmd object's buffer (since it is the DC or SC byte) and decrements the length by one. So a buffer that contains 2 bytes such as kNXT_DirectCmd, kNXT_DCGetBatteryLevel will be sent as just one byte (kNXT_DCGetBatteryLevel) with a length of 1. Internally it appends the direct command byte ORed with the require response flag and it increments the length by one. Again, see how I do this exact thing using iNXT_read and iNXT_write in my working implementation of iNXT_sendSystemCommand and iNXT_sendDirectCommandEx in FantomSpirit.pas.
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetBatteryLevel);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 4, status);
cmd.MakeCmdWithFilename(kNXT_DirectCmd, kNXT_DCStartProgram, tmp);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 2, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCStopProgram);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetOutputState, aPort);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 24, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetInputValues, aPort);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 15, status);
cmd.SetVal(b, kNXT_DCKeepAlive);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 6, status)
cmd.SetVal(kNXT_DirectCmd, kNXT_DCLSGetStatus, aPort);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 3, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCLSRead, aPort);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 19, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetCurrentProgramName);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 22, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetButtonState, idx, Ord(reset));
cmd.SetVal(kNXT_DirectCmd, kNXT_DCMessageRead, remote, local, Ord(remove));
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 63, status);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetVMState);
iNXT_sendDirectCommandEnhanced(fNXTHandle, 1, cmd.BytePtr, cmd.Len, dcBuffer, 6, status, True);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCSetVMState, state);
cmd.SetVal(kNXT_DirectCmd, kNXT_DCGetProperty, kNXT_Property_Debugging);
const
NXT_CMD_RESPONSE_LENGTH : array[0..$ff] of byte = (
3, // DCStartProgram (x00)
3, // DCStopProgram (x01)
3, // DCPlaySoundFile (x02)
3, // DCPlayTone (x03)
3, // DCSetOutputState (x04)
3, // DCSetInputMode (x05)
25, // DCGetOutputState (x06)
16, // DCGetInputValues (x07)
3, // DCResetInputScaledValue (x08)
3, // DCMessageWrite (x09)
3, // DCResetMotorPosition (x0a)
5, // DCGetBatteryLevel (x0b)
3, // DCStopSoundPlayback (x0c)
7, // DCKeepAlive (x0d)
4, // DCLSGetStatus (x0e)
3, // DCLSWrite (x0f)
20, // DCLSRead (x10)
23, // DCGetCurrentProgramName (x11)
0, // DCGetButtonState (not implemented) (x12)
64, // DCMessageRead (x13)
0, // DCRESERVED1 (x14)
0, // DCRESERVED2 (x15)
0, // DCRESERVED3 (x16)
0, // DCRESERVED4 (x17)
0, // DCRESERVED5 (x18)
64, // DCDatalogRead (1.28+) (x19)
3, // DCDatalogSetTimes (1.28+) (x1a)
4, // DCBTGetContactCount (1.28+) (x1b)
21, // DCBTGetContactName (1.28+) (x1c)
4, // DCBTGetConnCount (1.28+) (x1d)
21, // DCBTGetConnName (1.28+) (x1e)
3, // DCSetProperty(1.28+) (x1f)
7, // DCGetProperty (1.28+) (x20)
3, // DCUpdateResetCount (1.28+) (x21)
7, // RC_SET_VM_STATE (enhanced only) (x22)
7, // RC_GET_VM_STATE (enhanced only) (x23)
15, // RC_SET_BREAKPOINTS (enhanced only) (x24)
15, // RC_GET_BREAKPOINTS (enhanced only) (x25)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x26-x2f)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x30-x3f)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x40-x4f)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x50-x5f)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x60-x6f)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (x70-x7f)
8, // OPENREAD = 0x80,
4, // OPENWRITE = 0x81,
64, // READ = 0x82, (actually is a variable length response)
6, // WRITE = 0x83,
4, // CLOSE = 0x84,
23, // DELETE = 0x85,
28, // FINDFIRST = 0x86,
28, // FINDNEXT = 0x87,
7, // VERSIONS = 0x88,
4, // OPENWRITELINEAR = 0x89,
7, // OPENREADLINEAR = 0x8A, (not actually implemented)
4, // OPENWRITEDATA = 0x8B,
8, // OPENAPPENDDATA = 0x8C,
4, // CROPDATAFILE = 0x8D, /* New cmd for datalogging */
0, // XXXXXXXXXXXXXX = 0x8E,
0, // XXXXXXXXXXXXXX = 0x8F,
34, // FINDFIRSTMODULE = 0x90,
34, // FINDNEXTMODULE = 0x91,
4, // CLOSEMODHANDLE = 0x92,
0, // XXXXXXXXXXXXXX = 0x93,
64, // IOMAPREAD = 0x94, (actually is a variable length response)
9, // IOMAPWRITE = 0x95,
0, // XXXXXXXXXXXXXX = 0x96,
7, // BOOTCMD = 0x97, (can only be executed via USB)
3, // SETBRICKNAME = 0x98,
0, // XXXXXXXXXXXXXX = 0x99,
10, // BTGETADR = 0x9A,
33, // DEVICEINFO = 0x9B,
0, // XXXXXXXXXXXXXX = 0x9C,
0, // XXXXXXXXXXXXXX = 0x9D,
0, // XXXXXXXXXXXXXX = 0x9E,
0, // XXXXXXXXXXXXXX = 0x9F,
3, // DELETEUSERFLASH = 0xA0,
5, // POLLCMDLEN = 0xA1,
64, // POLLCMD = 0xA2,
44, // RENAMEFILE = 0xA3,
3, // BTFACTORYRESET = 0xA4,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (xA5-xAF)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (xB0-xBf)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (xC0-xCf)
0, // RESIZEDATAFILE = 0xD0,
0, // SEEKFROMSTART = 0xD1,
0, // SEEKFROMCURRENT = 0xD2,
0, // SEEKFROMEND = 0xD3
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (xD4-xDF)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, // (xE0-xEF)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 // (xF0-xFF)
