Page 3 of 3
Re: Most Prolific Poster Award
Posted: 19 Mar 2011, 16:12
[OT]
mightor wrote:
So why have drivers for NXT-G and not for NXC?
I already explained it to you. If you don't make drivers for a particular programming environment then you don't need to support them. That saves time and money.
HT does not support these Tetrix controllers, Lego Education does. If you find the support for NXC lacking then you need to take this up with Lego Education, not HT.
But HT is the manufacturer, right?
And they provided a i2c register table for Mux commands, right?
You can build a standard driver from it, sending the published values to the published registers, right?
And this has already be done (by me, by you, by some others), right?
But they don't work because the controller doesn't obey to the (simple, standard) commands, right?
But with Lego blocks it works - is that correct? Or isn't it?
So if it's working with the Lego blocks: then the published documentation is faulty, because Lego then must have used others than these instead.
Or isn't it working with the Lego blocks? then the controller firmware is faulty - or the documentation - or both.
But does HT care about anything of that? No.
Right?
[/OT]
matt: 644 / me: 629 :(
Posted: 19 Mar 2011, 17:24
by mightor
A list of registers does not always tell you the sequence of commands that need to be sent to a controller. It's like a description of every single button on an oil rig, does not tell you what you need to do to get oil out of the ground.
I just took a wild guess at some stuff and it didn't work, no big surprise there.
Just because it doesn't work the way you command it to, does not mean it doesn't work when you use it properly.
I have no idea, I would assume so or it would not have passed LEGO QC.
No, they probably just use them in the right sequence. A protocol analyser would help in this case and is often how I figure out how these things work.
Because they don't support that product, LEGO Education does. Do they care that you can't use it with NXC? Not a chance.
If you have a problem with the lack of support for NXC, complain to LEGO, not HT. HT does not control this product, they merely manufacture it.
I consider this subject closed now. If you want to complain more about it, I suggest you take it up with LEGO. All subsequent posts which I deem to be whining for or about support for this sensor, will be removed. I am not joking. You are bordering on trolling and you know it.
