Page 17 of 19
Re: wishlist for BricxCC
Posted: 17 Mar 2012, 01:52
by nxtboyiii
Just the 2 50ms frames before, since NXTScreen has the max refresh rate of 50ms.
Posted: 17 Mar 2012, 02:17
First, I'd like to put in a request for a mod to move this unrelated stuff to another topic if necessary.
@nxtboyiii, I don't think you understand how it works. In order to do what you want, the NXT would need 3 screen buffers, and the computer would need a tool that is capable of polling all 3 and displaying them each with 1/3 opacity.
Posted: 17 Mar 2012, 05:31
by nxtboyiii
I'm just saying this:
First, the computer saves a screenshot of NXTScreen as a .png, or whatever.
50 ms later, it saves another screenshot as a different file.
After another 50 ms, it saves the final screenshot.
It then displays all those images on NXTScreen each at 33% opacity.
Then it shifts back all the images, and repeats.
Posted: 17 Mar 2012, 05:41
That would require perfect sync of the NXT program with the tool the computer is using. Also, you don't save files for stuff that temporary, you use RAM.
Posted: 17 Mar 2012, 20:48
John,
why isn't it posible to make *.h files work with BCC just like *.nxc files (for text highlighting and debugging)?
Posted: 17 Mar 2012, 21:01
To add to what Helmut suggested, what about a way to easily add key words for it to highlight?
Posted: 17 Mar 2012, 21:08
by nxtboyiii
Perfect sync? This "tool" would be an option when you right click. It would be built in to NXTScreen.
Posted: 17 Mar 2012, 21:43
nxtboyiii wrote:Perfect sync? This "tool" would be an option when you right click. It would be built in to NXTScreen.
It would need a way of knowing that it isn't grabbing a frame that is half-built. It would also need to get frames 1, 2, and 3 without mixing up, or getting (for example) 2, 2, and 3.
I think you would be better off making your own PC program, and have the running NXT program supply the frames.
Posted: 17 Mar 2012, 21:58
hi yall -
nxtboy3, matt:
I strongly doubt that this is still about a wish list issue you are talking about...?
John already posted his reply:
afanofosc wrote:That's not going to be possible.
I would recommend to clean this thread and start a new one!
(wish list threads shouldn't be for discussing IMO)
to make sure that real wishes will not get dropped between discussion, the following was my wish in memory:
doc-helmut wrote:John,
Posted: 18 Mar 2012, 00:29
Yes, you are right, but it seems more often than not, you are the one that starts the conversations.
