Page 13 of 19
Re: wishlist for BricxCC
Posted: 21 Feb 2012, 20:32
ps:
if I have opened "ChessMaster.nxc" I must be sure that this BCC instance with this program is controlling NXT 000,
if another BCC instance runs "ChessSlave1.nxc" I must be sure that this BCC instance is controlling NXT 001,
if the 3rd BCC instance runs "ChessSlave2.nxc" I must be sure that this BCC instance is controlling NXT 002,
a.s.o.
If a certain BCC instance is incidentally conncted to the wrong brick, I must be able to reconnect it to the correct brick (by a selection menu).
Posted: 21 Feb 2012, 20:34
Well, you go through the menu on the NXT and you find the MAC address. You then find the matching listing in nxt.dat, and you name it whatever you want.
Posted: 21 Feb 2012, 20:37
If you connect to the wrong NXT, disconnect (Close communication) and then connect to the right one (Find brick).
Posted: 21 Feb 2012, 21:09
ok,I found the MAC address. I can adjust the aliases.
But if I have 3 BCC instances running and 3 (or even 4) NXTs are connected to 3 (4) different USB ports, how will BCC instance 2 know how to connect to NXT 000 and how can BCC instance 3 connect to 001 ?
Posted: 21 Feb 2012, 23:14
When you connect to the brick, don't select "usb", instead, select one of your aliases (the one for the NXT you want to connect to).
Posted: 22 Feb 2012, 07:55
aaah - now it's clear, thank you!
Posted: 22 Feb 2012, 16:12
by afanofosc
I will see if the value that I write to the status bar helps make clear which NXT the IDE is connected to.
Posted: 22 Feb 2012, 20:25
e.g, my NXT 001 has ID 0016530EEBDF
i find in nxt.dat
alias1=USB0::0X0694::0X0002::0016530EEBDF::RAW
I changed alias1 into NXT001
NXT001=USB0::0X0694::0X0002::0016530EEBDF::RAW
but now BCC don't find it any more
:shock:
choosing "usb" instead everything's still fine.
Posted: 22 Feb 2012, 20:29
Did you save nxt.dat, and then restart BCC? You could try restarting the NXT as well.
Posted: 22 Feb 2012, 20:55
yes, of course:
close BCC
open nxt.dat, edit, svae, close
start BCC
choose "NXT001" => no connection
find brick
choose "usb"
(all fine)
I didn't restart the NXT, but why should I? the ID has not been changed!
