NXC: can't pass expression to ArrayInit
Re: NXC: can't pass expression to ArrayInit
BTW, what means "especially of late you are not making me eager to help you or to implement items from your NXC wish list"? why am I late?
"especially of late" means "more than usual right now".
Just use the workarounds.
Besides, you do realize there's a 256 function/task limit in the firmware? (Kinda sucks, I know.) I don't think that it's easily fixable, since the RXE format will have to change... right?
though it's OT - yes, you're right, but it's still within the limits of my code.
IIRC RobotC has a limit of main + 19 tasks, that REALLY sucks. Anyhow, it has function overloading.
But no recursion neither.
To show how easy it was if we had recursion to calculate ALL determinates of matrices of ANY size, look at this (cody by Fenris, not optimized yet for development from most efficient row or column):
    void MatrixUntermatrix(float A[][], float R, float S, float R_, float S_, float &B[][])
            int r, s;
            for (s = 0; s < S-1; s++)
                    for (r = 0; r < R-1; r++)
                            B[s][r] = A[s + (s >= S_)][r + (r >= R_)];
    float MatrixDeterminanteAllgemein(float A[][], int R)
            int r;
            float U[][];
            float det = 0;
            if (R == 0) return 1;
                    for (r = 0; r < R; r++)
                            MatrixUntermatrix(A, R, R, 0, r, U);
                            det += (r%2 ? -1 : +1) * A[0][r] * MatrixDeterminante(U, R-1);
                    return det;
so I have to see that I won't reach the 256 limit nevertheless.
But let's stop getting OT (there's an OT section, I've heard recently )^^
Use this:
#define ArrayInitExp(_aout, _val, _cnt) { \
    unsigned int _cnt_eval = _cnt; \
    asm { arrinit _aout, _val, _cnt_eval } \
Or:
#define ArrayInitExpType(_type, _aout, _val, _cnt) { \
    _type _val_eval = _val; \
    asm { arrinit _aout, _val_eval, _cnt_eval } \
P.S. I just realized that inline functions don't count towards the 256 limit. :)
what does that mean?
int arr[];
int a = 4;
int b = 5;
ArrayInitExp(arr, 42, a * b);
// arr[20];
// ArrayInitExpType(int, arr, a / 2 * 21, a * b);
Just paste the #define code in my previous post into your program.
what is this for?
how does it refer to "recursion" or to "pass expressions to asm-code"?
hergipotter
Post by hergipotter »
You could at least try to understand the code, its not that complicated ;)
With this code you can pass expressions to ArrayInit
for passing expressions to ArrayInit I don't need that code.
I can simply use a temp variable and pass the temp variable to ArrayInit.
The point is, passing it directly, without having to produce spaghetti (or obfuscated asm) code.
doc-helmut wrote:The point is, passing it directly, without having to produce spaghetti (or obfuscated asm) code.
Please give an example of what you want. (The implementation.)
Do you want ArrayInit() to become the compiler's job? (i.e. "direct" translation, with no #defines) I don't see what's wrong with using #defines. What difference does it make? NXC will never be "a real C compiler".
Maybe John could put the ArrayInitExp() code to replace the current ArrayInit()? Would that be sufficient? I can't see any other ways of doing this. (Excluding void*s, malloc(), and that sort of stuff. Function overloading wouldn't work too well with multi-dimensional arrays, I believe.)
Locked
