NXC: program blocks caused by PlayTones()
Re: NXC: program blocks caused by PlayTones()
I just encountered the same issue when adding a PlayTones(...) to Davic Gilday's Mindcuber for debugging reasons:
If I insert this command quite at the end of his code, it seems the turn table doesn't execute turn(8) any more, and the program blocks....
while cheaping a very high frequent sqeaking noise (presumably 12 kHz)
...at least temporarily for several minutes as I now observed ...!!! (3 times it unexpectedly continued again after about 5-10 minutes !)
  Tone ChordUp[] = {TONE_C4, 50, TONE_E4, 50, TONE_G4, 50,
    TONE_C5, 50, TONE_E5, 50, TONE_G5, 50, TONE_C6, 200};
//*SNIP*
  if (solved)  {
      PlayTones(ChordUp); // <<<<<<<<<<<<<<<<<<<<<<<<<<<
      turn(8);
 * Title               : MindCuber
 * Author              : David Gilday
 * Copyright           : (C) 2011-2013 David Gilday
 * Website             : http://mindcuber.com
 * Release Information : v2.1
 * Modified            : $Date: 2013-06-22 13:28:00 +0100 (Sat, 22 Jun 2013) $
 * Revision            : $Revision: 6389 $
 * Usage:
 *   This software may be used for any non-commercial purpose providing
 *   that the original author is acknowledged.
 * Disclaimer:
 *   This software is provided 'as is' without warranty of any kind, either
 *   express or implied, including, but not limited to, the implied warranties
 *   of fitness for a purpose, or the warranty of non-infringement.
 * Purpose : NXT software for MindCuber
// Define NXT_8527 to run on the "Orange Box" variant of MindCuber rather
// than the default variant for NXT 2.0
//#define NXT_8527
// Define SOLVE_PATTERN and one or more PATTERN_...s to "solve" to a pattern
// If ONLY_PATTERNS is also defined, MindCuber will always create one of the
// patterns selected at random, otherwise MindCuber will solve the cube
// normally most of the time and occasionally create one of the patterns
//#define SOLVE_PATTERN
//#define ONLY_PATTERNS
Tone ChordDn[] = {TONE_C6, 50, TONE_G5, 50, TONE_E5, 50,
  TONE_C5, 50, TONE_G4, 50, TONE_E4, 50,  TONE_C4, 200};
Tone Chord[] = {TONE_C4, 50, TONE_E4, 50, TONE_G4, 50, TONE_C5, 50};
Tone Beep[] = {TONE_C5, 200};
Tone BeepBeep[] = {TONE_C5, 200 , 0, 100, TONE_C5, 200};
Tone Blip[] = {TONE_C7, 10 };
Tone BlipBlip[] = {TONE_C7, 10, 0, 20, TONE_C7, 10 };
Tone Buzz[] = {220, 200 };
Tone sdError[] = {TONE_C4, 50, 0, 50, TONE_C4, 50, 0, 50, TONE_C4, 50};
#define NXT_8527
#define PATTERN_CHECKERBOARD
#define PATTERN_SPOT
#define PATTERN_SNAKE
#define PATTERN_CUBES
#define PATTERN_SUPERFLIP
// Define HITECHNIC_V2 to include code to support the HiTechnic v2 color
// sensor (as an alternative the default LEGO color sensor)
// Note: this code is untested and may need modifications to make it work
//#define HITECHNIC_V2
// Define LOG to enable logging to a file to help diagnose color
// discrimination issues
//#define LOG
// Include lookup tables of moves
#include "mcmoves.h"
void banner() {
#ifdef SOLVE_PATTERN
  TextOut(0, LCD_LINE1, "MindCuber v2.1p");
  TextOut(0, LCD_LINE2, "---------------");
#else
  TextOut(0, LCD_LINE1, "MindCuber v2.1");
  TextOut(0, LCD_LINE2, "--------------");
#endif
#define LCD_LINE_OFF (LCD_LINE2-LCD_LINE1)
#ifdef LOG
string       logname = "mc.log";
byte         logh;
bool         logf = true;
void log(long n) {
  if (!logf)
    Write(logh, ',');
  if (n < 0) {
    Write(logh, '-');
    n = -n;
  long f = 10;
  while (n >= f)
    f *= 10;
  while (f > 1) {
    f /= 10;
    byte b = (n/f)%10+'0';
    Write(logh, b);
  logf = false;
void logeol() {
  byte eol = 10;
  Write(logh, eol);
  logf = true;
#define create_log()  DeleteFile(logname); CreateFile(logname, 18000, logh)
#define close_log()   CloseFile(logh)
#else
#define log(NUM)
#define logeol()
#define close_log()
#endif
#ifdef DEBUG
// Only include checks if DEBUG defined to save memory
void error(string mes, int num) {
  ClearLine(LCD_LINE1);
  TextOut(0, LCD_LINE1, "ERROR:");
  NumOut(8*6, LCD_LINE1, num);
  ClearLine(LCD_LINE2);
  TextOut(0, LCD_LINE2, mes);
  while (true)
    Wait(1);
#else
#define error(MES, NUM)
#endif
// Background task and routines to use color sensor as flashing light
#define S_CLR     IN_3
#define CLR_R     0
#define CLR_B     1
#define CLR_O     2
#define CLR_G     3
#define CLR_W     4
#define CLR_Y     5
#define L_DEL    1000
mutex light_mtx;
bool  light_flash = false;
int   light_clr   = CLR_R;
void color_sensor_on() {
#ifdef HITECHNIC_V2
  SetSensorLowspeed(S_CLR, true);
#else
  SetSensorColorFull(S_CLR);
  ResetSensor(S_CLR);
#endif
void color_sensor_off() {
#ifdef HITECHNIC_V2
  SetSensorLowspeed(S_CLR, false);
#else
  SetSensorType(S_CLR, SENSOR_TYPE_NONE);
#endif
task light_task() {
  long ms = CurrentTick();
  Acquire(light_mtx);
  while (light_flash) {
#ifdef HITECHNIC_V2
#else
    switch (light_clr) {
    case CLR_R: SetSensorColorRed(S_CLR);   break;
    case CLR_G: SetSensorColorGreen(S_CLR); break;
    case CLR_B: SetSensorColorBlue(S_CLR);  break;
#endif
    color_sensor_off();
    Release(light_mtx);
    ms += L_DEL;
    long del = ms-CurrentTick();
    if (del < 1)
      del = 1;
    else if (del > L_DEL)
      del = L_DEL;
    Wait(del);
    Acquire(light_mtx);
  Release(light_mtx);
void flash_on(int clr) {
  Acquire(light_mtx);
  light_clr = clr;
  if (!light_flash) {
    light_flash = true;
    start light_task;
  Release(light_mtx);
void flash_red() {
  flash_on(CLR_R);
void flash_green() {
  flash_on(CLR_G);
void flash_blue() {
  flash_on(CLR_B);
void flash_off() {
  Acquire(light_mtx);
  Release(light_mtx);
  color_sensor_off();
// Background task and routines to display timer during solve
mutex  tmr_mtx;
bool   tmr_on   = false;
long   tmr_time = 0;
string tmr_str  = "      ";
string ms_to_str(long ms) {
  long t = ms / 100;
  long s = t / 10;
  t %= 10;
  long m = s / 60;
  s %= 60;
  return NumToStr(m)+":"+NumToStr(s/10)+NumToStr(s%10)+"."+NumToStr(t);
task timer_task() {
  bool on = false;
  do {
    long del = 100;
    Acquire(tmr_mtx);
    on = tmr_on;
    if (on) {
      long t = CurrentTick()-tmr_time;
      del -= (t % 100);
      tmr_str = ms_to_str(t);
      TextOut(0, LCD_LINE8, tmr_str);
    Release(tmr_mtx);
    Wait(del);
  } while (on);
void timer_start() {
  Acquire(tmr_mtx);
  if (!tmr_on) {
    tmr_on   = true;
    tmr_time = CurrentTick();
    start timer_task;
  Release(tmr_mtx);
void timer_stop() {
  Acquire(tmr_mtx);
  tmr_on = false;
  Release(tmr_mtx);
// Routines to detect the presence of a cube using the ultrasonic sensor
#define S_ULTRA   IN_2
#define CD_DIST   18
#define CD_DELAY  200
#define CD_COUNT  5
bool cd_on    = false;
long cd_time  = 0;
int  cd_count = 0;
bool check_cube_detect() {
  if (!cd_on) {
    cd_on    = true;
    cd_time  = CurrentTick();
    cd_count = 0;
    SetSensorUltrasonic(S_ULTRA);
    ResetSensor(S_ULTRA);
  long diff = CurrentTick()-cd_time;
  if (diff > 0) {
    cd_time += CD_DELAY;
    return true;
  return false;
void cube_detect_off() {
  cd_on = false;
  SetSensorType(S_ULTRA, SENSOR_TYPE_NONE);
bool cube_present() {
  if (check_cube_detect()) {
    if (SensorUS(S_ULTRA) < CD_DIST)
      cd_count ++;
      cd_count = 0;
  return cd_count >= CD_COUNT;
bool cube_absent() {
    if (SensorUS(S_ULTRA) >= CD_DIST)
      cd_count ++;
      cd_count = 0;
// Routines to detect button presses with auto-repeat when held
#define BTN_AUTO_REPEAT_FIRST   1000
#define BTN_AUTO_REPEAT         30
long btn_time   = 0;
bool btn_left   = false;
bool btn_right  = false;
bool btn_center = false;
bool btn_auto_repeat(byte btn, bool &btn_pressed) {
  if (ButtonPressed(btn, false)) {
    if (btn_pressed) {
      long diff = CurrentTick()-btn_time;
      if (diff >= 0) {
        btn_time += BTN_AUTO_REPEAT;
        return true;
    } else {
      btn_pressed = true;
      btn_time = CurrentTick()+BTN_AUTO_REPEAT_FIRST;
      return true;
  } else
    btn_pressed = false;
  return false;
bool left_pressed() {
  return btn_auto_repeat(BTNLEFT, btn_left);
bool right_pressed() {
  return btn_auto_repeat(BTNRIGHT, btn_right);
bool center_pressed() {
  return btn_auto_repeat(BTNCENTER, btn_center);
// Background task and low level routines to control motors
#define NMOTORS 3
#define M_DELAY  10
#define M_SCALE  12
#define AMAX     24
#define VMAX     100
#define P_LOW    35
#define P_HIGH   85   // default: 87
#define Pa_HIGH  95
#define Pc_HIGH  76
mutex      motor_mtx;
const byte mmot[] = {OUT_A, OUT_B, OUT_C};
bool       mon[]  = {false, false, false};
bool       mgo[]  = {false, false, false};
bool       mup[]  = {false, false, false};
long       mtx[]  = {0, 0, 0};
long       mx[]   = {0, 0, 0};
long       mv[]   = {0, 0, 0};
long       ma[]   = {0, 0, 0};
long       mp[]   = {0, 0, 0};
long       me[]   = {0, 0, 0};
void motors_on() {
  Acquire(motor_mtx);
  for (int m = 0; m < NMOTORS; m++)
    mon[m] = true;
  Release(motor_mtx);
void motors_off() {
  bool on;
  do {
    on = false;
    Acquire(motor_mtx);
    for (int m = 0; m < NMOTORS; m++) {
      if (mon[m]) {
        if (mgo[m]) {
          on = true;
        } else {
          byte mot = mmot[m];
          OffEx(mot, RESET_NONE);
          mon[m] = false;
          mv[m]  = 0;
          ma[m]  = 0;
          mp[m]  = 0;
    Release(motor_mtx);
    Wait(1);
  } while (on);
void endstop(int m) {
  long p0, p1;
  byte mot = mmot[m];
  Acquire(motor_mtx);
  mon[m] = false;
  Release(motor_mtx);
  OnFwdEx(mot, P_LOW, RESET_NONE);
  p1 = MotorTachoCount(mot);
  do {
    Wait(500);
    p0 = p1;
  } while (p0 < p1);
  ResetTachoCount(mot);
  Wait(200);
task motor_task() {
  int pm_high;
  while (true) {
    Acquire(motor_mtx);
      if (mon[m]) {
        bool rev = false;
        byte mot = mmot[m];
        long x = mx[m];
        long v = mv[m];
        long a = ma[m];
        long p = mp[m];
        long e = 0;
        long ax = M_SCALE*MotorTachoCount(mot);
        long ex = ax-x;
        if (m==OUT_A) {pm_high=Pa_HIGH;}  // adjust tilt motor speed
        if (m==OUT_C) {pm_high=Pc_HIGH;}
        else pm_high=P_HIGH;
        if (-M_SCALE < ex && ex < M_SCALE)
          ax = x;
        else if (mgo[m])
          e  = me[m]-ex;
        long d = mtx[m]-ax;
        if (mup[m] ? (d < M_SCALE) : (d > -M_SCALE)) {
          mgo[m] = false;
          e = 0;
        if (d < 0) {
          d = -d;
          v = -v;
          a = -a;
          p = -p;
          e = -e;
          rev = true;
        if (d >= M_SCALE) {
          if (v >= 0) {
            long dd = (v+AMAX/2)+(v*v)/(2*AMAX);
            if (d >= dd) {
              p = pm_high;
              a = (AMAX*(VMAX-v))/VMAX;
              e = 0;
            } else {
              a = -(v*v)/(2*d);
              if (a < -v)
                a = -v;
              if (a < -AMAX)
                a = -AMAX;
              p = (pm_high*a*(VMAX-v))/(AMAX*VMAX);
          } else {
            a = -v;
            if (a > AMAX)
              a = AMAX;
            p = (pm_high*a*(VMAX+v))/(AMAX*VMAX);
        } else {
          a = -v;
          if (a < -AMAX)
            a = -AMAX;
          else if (a > AMAX)
            a = AMAX;
          p = (pm_high*a)/AMAX;
        d = v+a/2;
        v += a;
        p += e;
        if (p > pm_high) {
          p = pm_high;
          e = 0;
        } else if (p < -pm_high) {
          p = -pm_high;
          e = 0;
        if (rev) {
          d = -d;
          v = -v;
          a = -a;
          p = -p;
          e = -e;
        if (p != mp[m]) {
          if (p > 0)
            OnFwdEx(mot, p, RESET_NONE);
          else if (p < 0)
            OnRevEx(mot, -p, RESET_NONE);
          mp[m] = p;
        mx[m] = ax+d;
        mv[m] = v;
        ma[m] = a;
        me[m] = e;
    Release(motor_mtx);
    ms += M_DELAY;
    if (del < 1)
      del = 1;
    else if (del > M_DELAY)
      del = M_DELAY;
    Wait(del);
void move_wait(int m) {
  bool go;
  do {
    Wait(1);
    Acquire(motor_mtx);
    go = mgo[m];
    Release(motor_mtx);
  } while (go);
void move_abs(int m, long pos) {
  Acquire(motor_mtx);
  mtx[m] = -M_SCALE*pos;
  mup[m] = (mtx[m] > mx[m]);
  mon[m] = true;
  mgo[m] = true;
  Release(motor_mtx);
void move_rel(int m, long pos, long off = 0) {
  Acquire(motor_mtx);
  mtx[m] += -M_SCALE*(pos+off);
  mon[m] = true;
  mgo[m] = true;
  Release(motor_mtx);
  if (off != 0) {
    move_wait(m);
    Acquire(motor_mtx);
    mtx[m] -= -M_SCALE*off;
    mgo[m] = true;
    Release(motor_mtx);
// Routines for high level motor control for turn, scan and tilt movements
#define M_TURN  0
#define M_SCAN  1
#define M_TILT  2
#ifdef NXT_8527
#define T_90    210
#define T_CUT   6          // default 7
#define T_OVR   40         // default 48
#ifdef HITECHNIC_V2
#define T_SOFF  0
#define T_SCNT  15
#define T_SCNR  100
#define T_SEDG  83
#else
#define T_SOFF  12
#define T_SCNT  15
#define T_SCNR  105
#define T_SEDG  88
#endif
#define T_TILT  85
#define T_TAWY  25
#define T_TREL  62
#define T_THLD  160
#define T_ADJ   2
#else
#define T_90    270
#define T_CUT   10
#define T_OVR   57
#ifdef HITECHNIC_V2
#define T_SOFF  0
#define T_SCNT  10
#define T_SCNR  103
#define T_SEDG  87
#else
#define T_SOFF  10
#define T_SCNT  10
#define T_SCNR  103
#define T_SEDG  87
#endif
#define T_TILT  85
#define T_TAWY  25
#define T_TREL  62
#define T_THLD  160
#define T_ADJ   3
#endif
int apply_sign(int n, int d) {
  return (n < 0) ? -d : ((n > 0) ? d : 0);
void turn(int r) {
  move_rel(M_TURN, r*T_90);
  move_wait(M_TURN);
void turn45(void) {
  move_rel(M_TURN, -T_90/2);
void turn_face(int r, int rn) {
  move_rel(M_TURN, r*T_90, apply_sign(r, T_OVR)+apply_sign(rn, T_CUT));
  move_wait(M_TURN);
void scan_to_center() {
  move_abs(M_SCAN, T_SCNT);
  move_wait(M_SCAN);
void scan_to_corner() {
  move_abs(M_SCAN, T_SCNR);
void scan_to_edge() {
  move_abs(M_SCAN, T_SEDG);
void scan_away() {
  move_abs(M_SCAN, 200);
void scan_wait() {
  move_wait(M_SCAN);
void scan_turn_wait() {
  move_wait(M_SCAN);
  move_wait(M_TURN);
bool holding = false;
void tilt_away() {
  holding = false;
  move_abs(M_TILT, T_TAWY);
  move_wait(M_TILT);
void tilt_release() {
  holding = false;
  move_abs(M_TILT, T_TREL);
  move_wait(M_TILT);
void tilt_hold() {
  holding = true;
  move_abs(M_TILT, T_THLD);
  move_wait(M_TILT);
void tilt(int n = 1) {
  if (holding) {
    Wait(100);
  } else {
    tilt_hold();
    Wait(350);
  for (int i = 0; i < n; i++) {
    if (i > 0) {
      move_wait(M_TILT);
      Wait(500);
    int t = T_TILT;
    move_rel(M_TILT, t);
    move_wait(M_TILT);
    Wait(150);
    move_rel(M_TILT, -t, -25);
    move_wait(M_TILT);
// Routines for color space conversion and color sorting
#define NFACE       6                // number of faces in cube
#define POS(FF, OO) (((FF)*8)+(OO))
const long cmax = 1024;
int  sc_r[NFACE*9];
int  sc_g[NFACE*9];
int  sc_b[NFACE*9];
int  sc_h[NFACE*9];
int  sc_s[NFACE*9];
int  sc_l[NFACE*9];
int  sc_sl[NFACE*9];
char sc_clr[NFACE*9];
void set_rgb(int o, int &rgb[]) {
  long r = rgb[0];
  long g = rgb[1];
  long b = rgb[2];
  // Convert to hsl
  long h = 0;
  long s = 0;
  long l = 0;
  long sl = 0;
  long v = r; if (g > v) v = g; if (b > v) v = b;
  long m = r; if (g < m) m = g; if (b < m) m = b;
  l = (v+m)/2;
  if (l > 0) {
    long vm = v-m;
    s = vm;
    if (s > 0) {
      long vf = v+m;
      if (l <= (cmax/2))
        vf = (2*cmax)-vf;
      long r2 = (v-r)*vf/vm;
      long g2 = (v-g)*vf/vm;
      long b2 = (v-b)*vf/vm;
      if (r == v)
        h = (g == m) ? 5*cmax+b2 : 1*cmax-g2;
      else if (g == v)
        h = (b == m) ? 1*cmax+r2 : 3*cmax-b2;
        h = (r == m) ? 3*cmax+g2 : 5*cmax-r2;
      h += cmax; // rotate so R/B either side of 0
      h /= 6;
      if (h < 0)     h += cmax;
      if (h >= cmax) h -= cmax;
      sl = s*cmax/l;
  sc_r[o]  = r;
  sc_g[o]  = g;
  sc_b[o]  = b;
  sc_h[o]  = h;
  sc_s[o]  = s;
  sc_l[o]  = l;
  sc_sl[o] = sl;
  log(r);
  log(g);
  log(b);
  log(h);
  log(s);
  log(l);
  log(sl);
  logeol();
int clr_ratio(long c0, long c1) {
  int ratio = 0;
  if (c0 < c1)
    ratio = -(2000*(c1-c0)/(c1+c0));
  else if (c0 > c1)
    ratio =  (2000*(c0-c1)/(c1+c0));
  return ratio;
#define CMP_H    0
#define CMP_SL   1
#define CMP_SLR  2
#define CMP_L    3
#define CMP_LR   4
#define CMP_R_G  5
#define CMP_R_B  6
#define CMP_B_G  7
bool compare_clrs(const int cmp_fn, const int c0, const int c1) {
  bool cmp = false;
  switch (cmp_fn) {
  case CMP_H:   cmp = (sc_h[c1]  > sc_h[c0]);  break;
  case CMP_SL:  cmp = (sc_sl[c1] > sc_sl[c0]); break;
  case CMP_SLR: cmp = (sc_sl[c1] < sc_sl[c0]); break;
  case CMP_L:   cmp = (sc_l[c1]  > sc_l[c0]);  break;
  case CMP_LR:  cmp = (sc_l[c1]  < sc_l[c0]);  break;
  case CMP_R_G: cmp = (clr_ratio(sc_r[c1], sc_g[c1])
                       < clr_ratio(sc_r[c0], sc_g[c0])); break;
  case CMP_R_B: cmp = (clr_ratio(sc_r[c1], sc_b[c1])
                       < clr_ratio(sc_r[c0], sc_b[c0])); break;
  case CMP_B_G: cmp = (clr_ratio(sc_b[c1], sc_g[c1])
                       < clr_ratio(sc_b[c0], sc_g[c0])); break;
  default:      error("cmp_fn", cmp_fn); break;
  return cmp;
void sort_clrs(int &co[], const int s, const int n, const int cmp_fn) {
  const int e = s+n-2;
  int is = s;
  int ie = e;
  do {
    int il = e+2;
    int ih = s-2;
    for (int i = is; i <= ie; i++) {
      if (compare_clrs(cmp_fn, co[i+1], co[i])) {
        int o   = co[i];
        co[i]   = co[i+1];
        co[i+1] = o;
        if (i < il) il = i;
        if (i > ih) ih = i;
    is = il-1; if (is < s) is = s;
    ie = ih+1; if (ie > e) ie = e;
  } while (is <= ie);
void sort_colors(int &co[], const int t, const int s) {
  // Lightness
  sort_clrs(co, 0*s, 6*s, CMP_LR);
  // Saturation
  sort_clrs(co, 0*s, 3*s, CMP_SL);
  // Hue
  sort_clrs(co, 1*s, 5*s, CMP_H);
  // Red/Orange
  switch (t) {
  case 0: /* already sorted by hue */       break;
  case 1: sort_clrs(co, 1*s, 2*s, CMP_R_G); break;
  case 2: sort_clrs(co, 1*s, 2*s, CMP_B_G); break;
  case 3: sort_clrs(co, 1*s, 2*s, CMP_R_B); break;
  case 4: sort_clrs(co, 1*s, 2*s, CMP_SLR); break;
  case 5: sort_clrs(co, 1*s, 2*s, CMP_L);   break;
  int i;
  for (i = 0; i < s; i++)
    sc_clr[co[i]] = CLR_W;
  for (; i < 2*s; i++)
    sc_clr[co[i]] = CLR_R;
  for (; i < 3*s; i++)
    sc_clr[co[i]] = CLR_O;
  for (; i < 4*s; i++)
    sc_clr[co[i]] = CLR_Y;
  for (; i < 5*s; i++)
    sc_clr[co[i]] = CLR_G;
  for (; i < 6*s; i++)
    sc_clr[co[i]] = CLR_B;
// Routines to scan a face of the cube and calibrate white balance
long         white_rgb[] = {910, 960, 1024};
unsigned int rgbn[INPUT_NO_OF_COLORS];
void sample_rgb(int &rgb[], int f, int o, bool cal) {
  const int scan_max = 5;
  Wait(10);
  for (int i = 0; i < 3; i++)
    rgb[i] = 0;
  for (int n = 0; n < scan_max; n++) {
#ifdef HITECHNIC_V2
    unsigned int r, g, b, w;
    do {
      Wait(1);
    } while (!ReadSensorHTRawColor2(S_CLR, r, g, b, w));
    rgbn[INPUT_RED]   = r / 4;
    rgbn[INPUT_GREEN] = g / 64;
    rgbn[INPUT_BLUE]  = (b > 20000) ? (b-20000)/48 : 0;
    rgbn[INPUT_BLANK] = w / 64;
#else
    do {
      Wait(1);
    } while (!ReadSensorColorRaw(S_CLR, rgbn));
#endif
    rgb[0] += rgbn[INPUT_RED];
    rgb[1] += rgbn[INPUT_GREEN];
    rgb[2] += rgbn[INPUT_BLUE];
    log(rgbn[INPUT_RED]);
    log(rgbn[INPUT_GREEN]);
    log(rgbn[INPUT_BLUE]);
    log(rgbn[INPUT_BLANK]);
    logeol();
  for (int i = 0; i < 3; i++) {
    if (cal) {
      rgb[i] /= scan_max;
      white_rgb[i] += rgb[i];
    } else {
      rgb[i] = (white_rgb[i]*rgb[i])/(scan_max*cmax);
int scan_rgb[3];
void scan_face(int n, int f, int o, bool cal = false) {
  TextOut(0, LCD_LINE6, "Face");
  NumOut(5*6, LCD_LINE6, n);
  log(f);
  logeol();
  tilt_release();
  move_rel(M_TURN, T_SOFF);
  scan_to_center();
  sample_rgb(scan_rgb, f, 8, cal);
  int orgb = f*9+8;
  for (int i = 0; i < 4; i++) {
    turn45();
    scan_to_corner();
    set_rgb(orgb, scan_rgb);
    scan_turn_wait();
    sample_rgb(scan_rgb, f, o, cal);
    orgb = f*9+o;
    turn45();
    scan_to_edge();
    scan_turn_wait();
    sample_rgb(scan_rgb, f, o+1, cal);
    orgb += 1;
    o = (o+2)&7;
  move_rel(M_TURN, -T_SOFF);
  if (n != 6)
    scan_away();
string cfg_name = "mccfg.dat";
byte   cfgh;
void calibrate_white() {
  flash_off();
  color_sensor_on();
    white_rgb[i] = 0;
  scan_face(1, 3, 2, true);
  long cmin = white_rgb[0];
  for (int i = 1; i < 3; i++) {
    if (white_rgb[i] < cmin)
      cmin = white_rgb[i];
    white_rgb[i] = (cmax*cmin)/white_rgb[i];
    NumOut(5*i*6, LCD_LINE5, white_rgb[i]);
  // Save white calibration value to a configuration file
  DeleteFile(cfg_name);
  if (CreateFile(cfg_name, 100, cfgh) == LDR_SUCCESS) {
    Write(cfgh, white_rgb);
    CloseFile(cfgh);
  flash_blue();
// Face indices
#define U        0
#define F        1
#define D        2
#define B        3
#define R        4
#define L        5
// Sequences of moves for patterns
#ifdef PATTERN_CHECKERBOARD
const byte checkerboard_fce[] = { U, D, F, B, L, R};
const char checkerboard_rot[] = { 2, 2, 2, 2, 2, 2};
#endif
#ifdef PATTERN_SPOT
const byte spot_fce[] = { L, R, F, B, U, D, L, R};
const char spot_rot[] = {-1, 1, 1,-1, 1,-1,-1, 1};
#endif
#ifdef PATTERN_SNAKE
const byte snake_fce[] = { F, L, U, L, B, U, B, L, U, L, F, L, U, F};
const char snake_rot[] = {-1,-1, 1, 1, 2, 1, 2, 1,-1, 1,-1, 2,-1, 2};
#endif
#ifdef PATTERN_CUBES
const byte cubes_fce[] = { U, R, D, F, R, U, R, U, R, U, R, L, D, L, F, D, R};
const char cubes_rot[] = {-1, 1,-1,-1, 1, 2, 2,-1,-1, 1, 2, 1,-1,-1, 2, 2,-1};
#endif
#ifdef PATTERN_SUPERFLIP
const byte superflip_fce[] = { U, F, R, U, R, D, F, B, U, F, R, L, F, D, B, R, F, D, F, D};
const char superflip_rot[] = {-1, 2,-1, 2, 2, 2, 1,-1,-1, 2, 1, 1,-1, 2,-1, 2,-1, 2,-1,-1};
#endif
#endif
// Routines to display, transform and solve a cube
// Target moves for solve to finish early to save time
// Average: 42 moves in 5 seconds
// Range:   about 37 to 47 moves in 1 to 10 seconds
#define TARGET  42
#define NPIECE   3    // maximum number of pieces indexed in one phase
#define MV_MAX   100  // maximum number of moves per solve
#define RFIX(RR) ((((RR)+1)&3)-1)  // Normalise to range -1 to 2
#define CHR_R    'r'
#define CHR_B    'b'
#define CHR_O    'o'
#define CHR_G    'g'
#define CHR_W    'w'
#define CHR_Y    'y'
char clr_chr[] = {CHR_R, CHR_B, CHR_O, CHR_G, CHR_W, CHR_Y};
void display_face(int x, int y, byte &cube[], int f, int o) {
  byte str[4];
  str[3] = 0;
  int b = f * 8;
  str[0] = clr_chr[cube[b+  o      ]];
  str[1] = clr_chr[cube[b+ (o+1)   ]];
  str[2] = clr_chr[cube[b+((o+2)&7)]];
  TextOut(x, y, ByteArrayToStr(str));
  str[0] = clr_chr[cube[b+((o+7)&7)]];
  str[1] = clr_chr[f];
  str[2] = clr_chr[cube[b+((o+3)&7)]];
  TextOut(x, y+LCD_LINE_OFF, ByteArrayToStr(str));
  str[0] = clr_chr[cube[b+((o+6)&7)]];
  str[1] = clr_chr[cube[b+((o+5)&7)]];
  str[2] = clr_chr[cube[b+((o+4)&7)]];
  TextOut(x, y+2*LCD_LINE_OFF, ByteArrayToStr(str));
void display_cube(byte &cube[]) {
  display_face(0,  LCD_LINE3, cube, U, 2);
  display_face(19, LCD_LINE3, cube, F, 2);
  display_face(38, LCD_LINE3, cube, D, 2);
  display_face(38, LCD_LINE6, cube, L, 4);
  display_face(57, LCD_LINE6, cube, B, 0);
  display_face(76, LCD_LINE6, cube, R, 4);
void init_cube(byte &cube[]) {
  int o = 0;
  for (byte f = 0; f < NFACE; f++)
    for (int i = 0; i < 8; i++)
      cube[o++] = f;
void copy_cube(byte &cube0[], byte &cube1[]) {
  int o = 0;
    for (int i = 0; i < 8; i++) {
      cube0[o] = cube1[o];
      o ++;
bool solved(byte &cube[]) {
  int o = 0;
      if (cube[o++] != f)
        return false;
  return true;
int  mv_n;
byte mv_f[MV_MAX];
int  mv_r[MV_MAX];
const byte opposite[] = {D, B, U, F, L, R};
void add_mv(int f, int r) {
  int  i   = mv_n;
  bool mrg = false;
  while (i > 0) {
    i--;
    int fi = mv_f[i];
    if (f == fi) {
      r += mv_r[i];
      r = RFIX(r);
      if (r != 0) {
        mv_r[i] = r;
      } else {
        mv_n --;
        while (i < mv_n) {
          mv_f[i] = mv_f[i+1];
          mv_r[i] = mv_r[i+1];
          i++;
      mrg = true;
      break;
    if (opposite[f] != fi)
      break;
  if (!mrg) {
    mv_f[mv_n] = f;
    mv_r[mv_n] = RFIX(r);
    mv_n++;
void rot_edges(byte &cube[], int r,
               int f0, int o0, int f1, int o1,
               int f2, int o2, int f3, int o3) {
  f0 *= 8;
  f1 *= 8;
  f2 *= 8;
  f3 *= 8;
  o0 += f0;
  o1 += f1;
  o2 += f2;
  o3 += f3;
  byte p;
  switch (r) {
  case 1:
    p = cube[o3];
    cube[o3] = cube[o2];
    cube[o2] = cube[o1];
    cube[o1] = cube[o0];
    cube[o0] = p;
    o0 ++; o1 ++; o2 ++; o3 ++;
    p = cube[o3];
    cube[o0] = p;
    o0 = f0+((o0+1)&7); o1 = f1+((o1+1)&7);
    o2 = f2+((o2+1)&7); o3 = f3+((o3+1)&7);
    p = cube[o3];
    cube[o0] = p;
    break;
  case 2:
    p = cube[o0];
    cube[o0] = cube[o2];
    cube[o2] = p;
    p = cube[o1];
    cube[o1] = cube[o3];
    cube[o3] = p;
    p = cube[o0];
    cube[o2] = p;
    p = cube[o1];
    cube[o3] = p;
    p = cube[o0];
    cube[o2] = p;
    p = cube[o1];
    cube[o3] = p;
    break;
  case 3:
    p = cube[o0];
    cube[o0] = cube[o1];
    cube[o1] = cube[o2];
    cube[o2] = cube[o3];
    cube[o3] = p;
    p = cube[o0];
    cube[o3] = p;
    p = cube[o0];
    cube[o3] = p;
    break;
  default:
    error("rot_edges", r);
void rotate(byte &cube[], int f, int r) {
  r &= 3;
  switch (f) {
  case U:  rot_edges(cube, r, B, 4, R, 0, F, 0, L, 0); break;
  case F:  rot_edges(cube, r, U, 4, R, 6, D, 0, L, 2); break;
  case D:  rot_edges(cube, r, F, 4, R, 4, B, 0, L, 4); break;
  case B:  rot_edges(cube, r, D, 4, R, 2, U, 0, L, 6); break;
  case R:  rot_edges(cube, r, U, 2, B, 2, D, 2, F, 2); break;
  case L:  rot_edges(cube, r, U, 6, F, 6, D, 6, B, 6); break;
  default: error("rot face", f);
  f *= 8;
  byte p;
  switch (r) {
  case 1:
    p         = cube[f+7];
    cube[f+7] = cube[f+5];
    cube[f+5] = cube[f+3];
    cube[f+3] = cube[f+1];
    cube[f+1] = p;
    p         = cube[f+6];
    cube[f+6] = cube[f+4];
    cube[f+4] = cube[f+2];
    cube[f+2] = cube[f];
    cube[f]   = p;
    break;
  case 2:
    p         = cube[f+1];
    cube[f+1] = cube[f+5];
    cube[f+5] = p;
    p         = cube[f+3];
    cube[f+3] = cube[f+7];
    cube[f+7] = p;
    p         = cube[f];
    cube[f]   = cube[f+4];
    cube[f+4] = p;
    p         = cube[f+2];
    cube[f+2] = cube[f+6];
    cube[f+6] = p;
    break;
  case 3:
    p         = cube[f+1];
    cube[f+1] = cube[f+3];
    cube[f+3] = cube[f+5];
    cube[f+5] = cube[f+7];
    cube[f+7] = p;
    p         = cube[f];
    cube[f]   = cube[f+2];
    cube[f+2] = cube[f+4];
    cube[f+4] = cube[f+6];
    cube[f+6] = p;
    break;
  default:
    error("rot", r);
int idx_ic;
int idx_ie;
int idx_idx[NPIECE];
int idx_nc;
int idx_ne;
int idx;
void index_init() {
  idx_nc = 0;
  idx_ne = 0;
  idx = 0;
void index_last() {
  idx = ((idx>>2)<<1)|(idx&1);
#define FIND_CORNER(F0, O0, F1, O1, F2, O2, I0, I1, I2) \
  c0 = cube[POS(F0, O0)]; \
  if (c0 == f0) { \
    if (cube[POS(F1, O1)] == f1 && \
        cube[POS(F2, O2)] == f2) return I2; \
  } else if (c0 == f2) { \
    if (cube[POS(F1, O1)] == f0 && \
        cube[POS(F2, O2)] == f1) return I1; \
  } else if (c0 == f1) { \
    if (cube[POS(F1, O1)] == f2 && \
        cube[POS(F2, O2)] == f0) return I0; \
int find_corner(byte &cube[], byte f0, byte f1, byte f2) {
  byte c0;
  FIND_CORNER(U, 2, B, 4, R, 2, 0,  1,  2);
  FIND_CORNER(U, 0, L, 0, B, 6, 3,  4,  5);
  FIND_CORNER(U, 6, F, 0, L, 2, 6,  7,  8);
  FIND_CORNER(U, 4, R, 0, F, 2, 9,  10, 11);
  FIND_CORNER(D, 0, L, 4, F, 6, 12, 13, 14);
  FIND_CORNER(D, 6, B, 0, L, 6, 15, 16, 17);
  FIND_CORNER(D, 4, R, 4, B, 2, 18, 19, 20);
  FIND_CORNER(D, 2, F, 4, R, 6, 21, 22, 23);
  return -1;
int index_corner(byte &cube[], byte f0, byte f1, byte f2) {
  int ic = find_corner(cube, f0, f1, f2);
  for (int i = 0; i < idx_nc; i++) {
    if (ic > idx_idx[i])
      ic -= 3;
  idx = (idx*idx_ic) + ic;
  idx_idx[idx_nc++] = ic;
  idx_ic -= 3;
#define FIND_EDGE(F0, O0, F1, O1, I0, I1) \
  e0 = cube[POS(F0, O0)]; \
  if (e0 == f0) { \
    if (cube[POS(F1, O1)] == f1) return I1; \
  } else if (e0 == f1) { \
    if (cube[POS(F1, O1)] == f0) return I0; \
int find_edge(byte &cube[], byte f0, byte f1) {
  byte e0;
  FIND_EDGE(U, 1, B, 5, 0,  1);
  FIND_EDGE(U, 7, L, 1, 2,  3);
  FIND_EDGE(U, 5, F, 1, 4,  5);
  FIND_EDGE(U, 3, R, 1, 6,  7);
  FIND_EDGE(L, 3, F, 7, 8,  9);
  FIND_EDGE(B, 7, L, 7, 10, 11);
  FIND_EDGE(D, 7, L, 5, 12, 13);
  FIND_EDGE(R, 3, B, 3, 14, 15);
  FIND_EDGE(D, 5, B, 1, 16, 17);
  FIND_EDGE(F, 3, R, 7, 18, 19);
  FIND_EDGE(D, 3, R, 5, 20, 21);
  FIND_EDGE(D, 1, F, 5, 22, 23);
  return -1;
void index_edge(byte &cube[], byte f0, byte f1) {
  int ie = find_edge(cube, f0, f1);
  for (int i = 0; i < idx_ne; i++) {
    if (ie > idx_idx[i])
      ie -= 2;
  idx = (idx*idx_ie) + ie;
  idx_idx[idx_ne++] = ie;
  idx_ie -= 2;
bool valid_pieces(byte &cube[]) {
  return
    (find_edge(cube, U, F) >= 0) &&
    (find_edge(cube, U, L) >= 0) &&
    (find_edge(cube, U, B) >= 0) &&
    (find_edge(cube, U, R) >= 0) &&
    (find_edge(cube, F, L) >= 0) &&
    (find_edge(cube, L, B) >= 0) &&
    (find_edge(cube, B, R) >= 0) &&
    (find_edge(cube, R, F) >= 0) &&
    (find_edge(cube, D, F) >= 0) &&
    (find_edge(cube, D, L) >= 0) &&
    (find_edge(cube, D, B) >= 0) &&
    (find_edge(cube, D, R) >= 0) &&
    (find_corner(cube, U, F, L) >= 0) &&
    (find_corner(cube, U, L, B) >= 0) &&
    (find_corner(cube, U, B, R) >= 0) &&
    (find_corner(cube, U, R, F) >= 0) &&
    (find_corner(cube, D, F, R) >= 0) &&
    (find_corner(cube, D, R, B) >= 0) &&
    (find_corner(cube, D, B, L) >= 0) &&
    (find_corner(cube, D, L, F) >= 0);
void solve_phase(byte &cube[], int mtb, const byte &mtd[], bool dorot = true) {
  int sz = ArrayLen(mtd)/mtb;
  idx = sz-idx;
  if (idx > 0) {
    int i = (idx-1)*mtb;
    byte b = mtd[i++];
    if (b != 0xFF) {
      const int mvm = mtb*2-1;
      int mv = 0;
      int f0 = b / 3;
      int r0 = RFIX(b-(f0*3)+1);
      add_mv(f0, r0);
      if (dorot)
        rotate(cube, f0, r0);
      mv ++;
      while (mv < mvm) {
        b >>= 4;
        if ((mv & 1) != 0)
          b = mtd[i++];
        byte b0 = b & 0xF;
        if (b0 == 0xF)
          break;
        int f1 = b0 / 3;
        r0 = RFIX(b0-(f1*3)+1);
        if (f1 >= f0)
          f1 ++;
        f0 = f1;
        add_mv(f0, r0);
        if (dorot)
        mv ++;
void solve_one(byte &cube[], bool dorot) {
  mv_n = 0;
  idx_ic = 24;
  idx_ie = 24;
  index_init();
  index_edge(cube, D, F);
  index_edge(cube, D, R);
  solve_phase(cube, mtb0, mtd0);
  index_init();
  index_corner(cube, D, F, R);
  index_edge(cube, F, R);
  solve_phase(cube, mtb1, mtd1);
  index_init();
  index_edge(cube, D, B);
  solve_phase(cube, mtb2, mtd2);
  index_init();
  index_corner(cube, D, R, B);
  index_edge(cube, R, B);
  solve_phase(cube, mtb3, mtd3);
  index_init();
  index_edge(cube, D, L);
  solve_phase(cube, mtb4, mtd4);
  index_init();
  index_corner(cube, D, B, L);
  index_edge(cube, B, L);
  solve_phase(cube, mtb5, mtd5);
  index_init();
  index_corner(cube, D, L, F);
  index_edge(cube, L, F);
  solve_phase(cube, mtb6, mtd6);
  index_init();
  index_corner(cube, U, R, F);
  index_corner(cube, U, F, L);
  index_corner(cube, U, L, B);
  solve_phase(cube, mtb7, mtd7);
  index_init();
  index_edge(cube, U, R);
  index_edge(cube, U, F);
  index_edge(cube, U, L);
  index_last();
  solve_phase(cube, mtb8, mtd8, dorot);
#define MAP(UU, FF) (imap[((UU)*NFACE)+(FF)]*NFACE)
const byte imap[] = {
  /*       U   F   D   B   R   L
  /* U */ -1,  0, -1,  1,  2,  3,
  /* F */  4, -1,  5, -1,  6,  7,
  /* D */ -1,  8, -1,  9, 10, 11,
  /* B */ 12, -1, 13, -1, 14, 15,
  /* R */ 16, 17, 18, 19, -1, -1,
  /* L */ 20, 21, 22, 23, -1, -1
const byte fmap[] = {
  /* UF */ U, F, D, B, R, L,
  /* UB */ U, B, D, F, L, R,
  /* UR */ U, R, D, L, B, F,
  /* UL */ U, L, D, R, F, B,
  /* FU */ F, U, B, D, L, R,
  /* FD */ F, D, B, U, R, L,
  /* FR */ F, R, B, L, U, D,
  /* FL */ F, L, B, R, D, U,
  /* DF */ D, F, U, B, L, R,
  /* DB */ D, B, U, F, R, L,
  /* DR */ D, R, U, L, F, B,
  /* DL */ D, L, U, R, B, F,
  /* BU */ B, U, F, D, R, L,
  /* BD */ B, D, F, U, L, R,
  /* BR */ B, R, F, L, D, U,
  /* BL */ B, L, F, R, U, D,
  /* RU */ R, U, L, D, F, B,
  /* RF */ R, F, L, B, D, U,
  /* RD */ R, D, L, U, B, F,
  /* RB */ R, B, L, F, U, D,
  /* LU */ L, U, R, D, B, F,
  /* LF */ L, F, R, B, U, D,
  /* LD */ L, D, R, U, F, B,
  /* LB */ L, B, R, F, D, U
const byte omap[] = {
  /* UF */ 0, 0, 0, 0, 0, 0,
  /* UB */ 4, 4, 4, 4, 0, 0,
  /* UR */ 6, 0, 2, 4, 4, 0,
  /* UL */ 2, 0, 6, 4, 0, 4,
  /* FU */ 4, 4, 4, 4, 2, 6,
  /* FD */ 0, 0, 0, 0, 6, 2,
  /* FR */ 6, 6, 2, 6, 4, 0,
  /* FL */ 2, 2, 6, 2, 0, 4,
  /* DF */ 4, 4, 4, 4, 4, 4,
  /* DB */ 0, 0, 0, 0, 4, 4,
  /* DR */ 6, 4, 2, 0, 4, 0,
  /* DL */ 2, 4, 6, 0, 0, 4,
  /* BU */ 0, 0, 0, 0, 2, 6,
  /* BD */ 4, 4, 4, 4, 6, 2,
  /* BR */ 6, 2, 2, 2, 4, 0,
  /* BL */ 2, 6, 6, 6, 0, 4,
  /* RU */ 4, 2, 0, 6, 2, 2,
  /* RF */ 2, 2, 2, 6, 2, 2,
  /* RD */ 0, 2, 4, 6, 2, 2,
  /* RB */ 6, 2, 6, 6, 2, 2,
  /* LU */ 4, 6, 0, 2, 6, 6,
  /* LF */ 6, 6, 6, 2, 6, 6,
  /* LD */ 0, 6, 4, 2, 6, 6,
  /* LB */ 2, 6, 2, 2, 6, 6,
int  solve_n;
byte solve_fce[MV_MAX];
int  solve_rot[MV_MAX];
byte solve_cube[NFACE*8];
void apply_pattern(byte &cube[], byte &pat_fce[], char &pat_rot[]) {
  // Add moves to transform solved cube into pattern
  for (int i = 0; i < ArrayLen(pat_fce); i++) {
    solve_fce[solve_n] = pat_fce[i];
    solve_rot[solve_n] = pat_rot[i];
    solve_n++;
  // Apply moves in reverse to a solved position and
  // replace the scanned cube with position that if
  // "solved" will result in the pattern
  copy_cube(cube, solve_cube);
  for (int i = solve_n-1; i >= 0; i--)
    rotate(cube, solve_fce[i], -solve_rot[i]);
#endif
bool solve_nomap(byte &cube[]) {
  solve_n = 0;
  copy_cube(solve_cube, cube);
  solve_one(solve_cube, true);
  if (!solved(solve_cube))
    return false;
  // Record the solution
  solve_n = mv_n;
  for (int i = 0; i < mv_n; i++) {
    solve_fce[i] = mv_f[i];
    solve_rot[i] = mv_r[i];
  if (
#ifdef ONLY_PATTERNS
      // Only create patterns and never a normal solve
      true
#else
      // If the cube is solved, always create a pattern
      solve_n == 0 ||
      // Otherwise decide at random to occasionally create a pattern
      // rather than a normal solve
      Random(6) == 0
#endif
    int pat = -1;
    while (pat < 0) {
      // Select one of the included patterns at random
      // (keep looping until one is selected and applied)
      pat = Random(5);
      switch (pat) {
      case 0:
        apply_pattern(cube, checkerboard_fce, checkerboard_rot);
        break;
#endif
#ifdef PATTERN_SPOT
      case 1:
        apply_pattern(cube, spot_fce, spot_rot);
        break;
#endif
      case 2:
        apply_pattern(cube, snake_fce, snake_rot);
        break;
#endif
      case 3:
        apply_pattern(cube, cubes_fce, cubes_rot);
        break;
#endif
      case 4:
        apply_pattern(cube, superflip_fce, superflip_rot);
        break;
#endif
      default:
        // Indicate that no pattern has been applied
        pat = -1;
        break;
#endif
  return true;
byte pmap[NFACE];
void solve_remap(byte &cube[], int map) {
  for (int f = 0; f < NFACE; f++)
    pmap[fmap[map+f]] = f;
  for (int f = 0; f < NFACE; f++) {
    int fs = fmap[map+f]*8;
    int fd = f*8;
    int os = omap[map+f];
    for (int od = 0; od < 8; od++) {
      solve_cube[fd+od] = pmap[cube[fs+os]];
      os = (os+1)&7;
  solve_one(solve_cube, false);
  if (mv_n < solve_n) {
    solve_n = mv_n;
      solve_fce[i] = fmap[map+mv_f[i]];
bool solve(byte &cube[]) {
  if (!solve_nomap(cube))
    return false;
  flash_blue();
  if (solve_n <= TARGET)
    return true;
  for (int i = 1; i < NFACE*4; i++) {
    solve_remap(cube, i*NFACE);
      return true;
  return true;
// High level routines to scan, solve and manipulate cube
byte clr_map[] = {0, 1, 2, 3, 4, 5};
int  clr_ord[NFACE*4];
void determine_colors(byte &cube[], const int t) {
  for (int i = 0; i < NFACE; i++)
    clr_ord[i] = 9*i+8;
  sort_colors(clr_ord, t, 1);
  for (int i = 0; i < NFACE; i++) {
    clr_ord[4*i+0] = 9*i+0;
    clr_ord[4*i+1] = 9*i+2;
    clr_ord[4*i+2] = 9*i+4;
    clr_ord[4*i+3] = 9*i+6;
  sort_colors(clr_ord, t, 4);
    clr_ord[4*i+0] = 9*i+1;
    clr_ord[4*i+1] = 9*i+3;
    clr_ord[4*i+2] = 9*i+5;
    clr_ord[4*i+3] = 9*i+7;
    clr_map[sc_clr[f*9+8]] = f;
  clr_chr[clr_map[CLR_R]] = CHR_R;
  clr_chr[clr_map[CLR_B]] = CHR_B;
  clr_chr[clr_map[CLR_O]] = CHR_O;
  clr_chr[clr_map[CLR_G]] = CHR_G;
  clr_chr[clr_map[CLR_W]] = CHR_W;
  clr_chr[clr_map[CLR_Y]] = CHR_Y;
    for (int o = 0; o < 8; o++)
      cube[POS(f, o)] = clr_map[sc_clr[f*9+o]];
int  uc = U;
int  fc = F;
int pieces_valid = 0;
int valid_i = 0;
bool scan_solve_cube(byte &cube[]) {
  flash_off();
  color_sensor_on();
  scan_face(1, 3, 2);
  tilt();
  scan_face(2, 2, 2);
  tilt();
  scan_face(3, 1, 2);
  tilt();
  scan_face(4, 0, 2);
  turn(-1);
  tilt();
  scan_face(5, 4, 6);
  tilt(2);
  scan_face(6, 5, 2);
  motors_off();
  flash_red();
  bool solved = false;
  TextOut(0*6, LCD_LINE1, "Processing...");
  for (int i = 0; i < 6; i++) {
    determine_colors(cube, i);
    if (valid_pieces(cube)) {
      pieces_valid ++;
      valid_i = i;
      display_cube(cube);
      if (solve(cube)) {
        solved = true;
        break;
  motors_on();
  display_cube(cube);
  if (solved) {
    TextOut(0, LCD_LINE1, "Solving...");
    scan_away();
    flash_off();
    scan_wait();
  } else {
    TextOut(0, LCD_LINE1, "Scan error...");
    if (pieces_valid > 1) {
      TextOut(0, LCD_LINE1, "Cube");
      flash_blue();
    } else {
      flash_red();
  uc = L;
  fc = D;
  return solved;
void manipulate(byte &cube[], int f, int r, int rn) {
  int map = MAP(uc, fc);
  if (fmap[map+U] == f) {
    uc = fmap[map+D]; fc = fmap[map+B];
    Wait(50);
    tilt(2);
  } else if (fmap[map+F] == f) {
    uc = fmap[map+B]; fc = fmap[map+U];
    Wait(50);
    tilt();
  } else if (fmap[map+D] == f) {
    tilt_hold();
  } else if (fmap[map+B] == f) {
    uc = fmap[map+F]; fc = fmap[map+U];
    tilt_release();
    turn(2);
    tilt();
  } else if (fmap[map+R] == f) {
    uc = fmap[map+L]; fc = fmap[map+U];
    tilt_release();
    turn(1);
    tilt();
  } else { // fmap[map+L] == f
    uc = fmap[map+R]; fc = fmap[map+U];
    tilt_release();
    turn(-1);
    tilt();
  Wait(150);
  rotate(cube, f, r);
  display_cube(cube);
  turn_face(-r, -rn);
// Main task controlling solve and calibration
int  recal = 0;
void calibrate_tilt() {
  if (recal <= 0) {
    // Calibrate tilt position at start and every 5 attempts
    // in case of tacho drift
    recal = 5;
    endstop(M_TILT);
    tilt_away();
  recal --;
task main() {
  byte cube[NFACE*8];
  SetSleepTimeout(0);
  banner();
#ifdef NXT_8527
  TextOut(0, LCD_LINE3, "NXT (Orange box)");
#else
  TextOut(0, LCD_LINE3, "NXT 2.0");
#endif
  TextOut(0, LCD_LINE4, "By David Gilday");
  TextOut(0, LCD_LINE5, "mindcuber.com");
  // Read the white calibration value from the configuration file
  unsigned int cfgl;
  if (OpenFileRead(cfg_name, cfgl, cfgh) == LDR_SUCCESS) {
    Read(cfgh, white_rgb);
    CloseFile(cfgh);
  start motor_task;
  flash_red();
  init_cube(cube);
  calibrate_tilt();
  endstop(M_SCAN);
  scan_away();
  scan_wait();
  motors_on();
  byte msg_line = LCD_LINE7;
  while (true) {
    ClearLine(msg_line);
    //PlayTones(Buzz);
    TextOut(0*6, msg_line, "Remove cube...");
    bool cal_white = false;
    while (!cube_absent()) {
      if (!cal_white && center_pressed()) {
        banner();
        TextOut(0*6, LCD_LINE4, "Calibrate white");
        cal_white = true;
      Wait(1);
    cube_detect_off();
    calibrate_tilt();
    flash_off();
    //PlayTones(Chord);
    TextOut(0*6, msg_line, "Insert cube...");
    while (!cube_present()) {
      if (left_pressed())
        move_rel(M_TURN, -T_ADJ);
      if (right_pressed())
        move_rel(M_TURN, T_ADJ);
      Wait(1);
    cube_detect_off();
    banner();
    TextOut(0*6, LCD_LINE4, "Scanning...");
    create_log();
    pieces_valid = 0;
    if (cal_white) {
      calibrate_white();
    } else {
      msg_line = LCD_LINE2;
      timer_start();
      for (int tries = 0; !solved && tries < 3; tries ++) {
        if (scan_solve_cube(cube)) {
          // Apply solution to the cube
          for (int i = 0; i < solve_n; i++) {
            int fi = solve_fce[i];
            int ri = solve_rot[i];
            int fo = opposite[fi];
            int rn = 0;
            for (int j = i+1; rn == 0 && j < solve_n; j++) {
              if (solve_fce[j] != fo)
                rn = solve_rot[j];
            TextOut(0*6, LCD_LINE2, "Move    of");
            NumOut(5*6,  LCD_LINE2, i+1);
            NumOut(11*6, LCD_LINE2, solve_n);
            manipulate(cube, fi, ri, rn);
          timer_stop();
          flash_green();
          banner();
          TextOut(0*6, LCD_LINE3, "Solved!");
          TextOut(0*6, LCD_LINE4, "Moves");
          NumOut(6*6,  LCD_LINE4, solve_n);
          TextOut(0*6, LCD_LINE5, "Time");
          TextOut(6*6, LCD_LINE5, tmr_str);
          solved = true;
      timer_stop();
    log(pieces_valid);
    log(valid_i);
    logeol();
    log(white_rgb[0]);
    log(white_rgb[1]);
    log(white_rgb[2]);
    logeol();
    close_log();
    scan_away();
    tilt_away();
    scan_wait();
    if (solved)  {
      turn(8);
// END
that's really strange IMO.
Perhaps this is caused by buggy array initialization:
This happens to work in simple cases. Perhaps it doesn't work quite right and causes bad things to happen in more complex situations?
Try properly initializing the array with Tone structures at runtime rather than using a technically invalid static initialization. You could also try copying the PlayTones function from NXCDefs.h and call it TestPlayTones in your own code and then try it with safecall or inline and see if it changes this behavior. I will need you to track down the problem while I focus on EV3 support, okay?
ok, thank you, it's not an urgent issue anyway.
is there anything syntactically wrong in the source code ? Or do you mean "going wrong" on compiler or firmware level?
(I currently use a small library of pre-defined melodies like ChordUp, ChordDown, Buzz, Beep, BeepError a.s.o. .)
As you can see, the initialization of ChordUp is not an array of Tone structures. It is just a flat array of values. There isn't a way to correctly statically initialize an array of structures with the current compiler - if I recall correctly. But you can use ArrayBuild with several temporary Tone structures to build an array at run time with the right Tone structures in it. Or you could ArrayInit an array with a Tone structure as the initial value that has zero values and then iterate through the array and set the correct tone and duration values in each Tone structure contained within the array. I have no idea if that is what is causing the problem. And that is why I am hoping you will at least try to diagnose it on your own. It should be quite simple to do but I am way behind on EV3 stuff so I really would prefer not to divert my attention to this issue.
ok, thank you, now I understand.
Building all those melodies in runtime is too complicated IMO.
I think then I'd better write an own PlayMelody function which is able to use a 1-dim array by Playtone(array, array[i+1]) and see what's happening then.
ps
I meanwhile checked the issue in your doxygen help and surprisingly found that you're still providing exactly the same code which I have been using so far -
would you maybe wish to update this source?
ex_playtones.nxc
This is an example of how to use the PlayTones function along with the Tone structure.
Tone sweepUp[] = {TONE_C4, MS_50, TONE_E4, MS_50, TONE_G4, MS_50,TONE_C5, MS_50, TONE_E5, MS_50, TONE_G5, MS_50, TONE_C6, MS_200};
PlayTones(sweepUp);
Wait(SEC_1);
update:
the following code runs fine without any issues:
int ChordUp[] = {TONE_C4, 50, TONE_E4, 50, TONE_G4, 50,
int ChordDn[] = {TONE_C6, 50, TONE_G5, 50, TONE_E5, 50,
int Chord[] = {TONE_C4, 50, TONE_E4, 50, TONE_G4, 50, TONE_C5, 50};
int Beep[] = {TONE_C5, 200};
int BeepBeep[] = {TONE_C5, 200 , 0, 100, TONE_C5, 200};
int Blip[] = {TONE_C7, 10 };
int BlipBlip[] = {TONE_C7, 10, 0, 20, TONE_C7, 10 };
int Buzz[] = {220, 200 };
int sdError[] = {TONE_C4, 50, 0, 50, TONE_C4, 50, 0, 50, TONE_C4, 50};
void PlayMelody( int melody[] ) {
  int l=SizeOf(melody)/2;
  for (int i=0; i<l-1; i+=2) {
     PlayTone(melody[i], melody[i+1]);
     Wait(melody[i+1]);
  //  *SNIP*
  PlayMelody(ChordUp);
  //  *SNIP*
Although it's already running fine, it even could be made thread-safe by
safecall void PlayMelody( int melody[] )
share and enjoy! ^^
It looks like at some point I enabled support for simple structure static initialization. Can you see if with this simple change the hanging trouble goes away? I.e., put { and } around the frequency and duration values as shown below:
Tone sweepUp[] = {
  { TONE_C4, MS_50 },
  { TONE_E4, MS_50 },
  { TONE_G4, MS_50 },
  { TONE_C5, MS_50 },
  { TONE_E5, MS_50 },
  { TONE_G5, MS_50 },
  { TONE_C6, MS_200 }
  PlayTones(sweepUp);
  Wait(SEC_1);
at the first attempt: no trouble any more (tried with the mindcuber program) ! :)
Excellent news. I will update the online help for this function to show the correct array initialization technique.
