Re: NXC and Braking
Posted: 19 Feb 2012, 19:56
Here's a link to my post with the ramping example.
https://sourceforge.net/apps/phpbb/mind ... ing#p11771
Included inline for easy access:
So in the above code I brake after ramping down but then, as written, it idles the motors which would release the brake. You can modify this as needed for your purposes. However, if your robotic arm requires power levels > 75 then ramping up and down may not work at all for you. Or maybe you could ramp down to something > 0 from a high power level across a much shorter percentage of the total tachometer rotation and then apply the brake.
Or you could stick with your approach of Coast/Off/Brake which you mention above.
void RotateMotorRURD(byte output, char pwr, long angle)
long l1, l2, l3;
char power = sign(angle);
angle = abs(angle);
power *= pwr;
l1 = angle*0.20;
l2 = angle*0.60;
l3 = angle-(l1+l2);
// we want to rotate a total of <angle> degrees
// we'll rampup from 0 power to specified power through 20% of the angle
// then run at the specified power for 70% of the angle
SetOutput(output, OutputModeField, OUT_MODE_MOTORON|OUT_MODE_BRAKE,
TachoLimitField, l1,
PowerField, power,
RegModeField, OUT_REGMODE_IDLE,
RunStateField, OUT_RUNSTATE_RAMPUP,
UpdateFlagsField, UF_UPDATE_MODE|UF_UPDATE_SPEED|UF_UPDATE_TACHO_LIMIT);
Yield(); // give firmware a chance to process this request to update motor state
// monitor runstate
while(MotorRunState(output) <> OUT_RUNSTATE_IDLE)
Yield();
// as soon as it goes idle put the motor into the running state
TachoLimitField, l2,
PowerField, power,
// monitor runstate
Yield();
// as soon as the runstate goes idle we rampdown to zero power
TachoLimitField, l3,
PowerField, 0,
RunStateField, OUT_RUNSTATE_RAMPDOWN,
// monitor runstate
Yield();
SetOutput(output, OutputModeField, OUT_MODE_MOTORON+OUT_MODE_BRAKE+OUT_MODE_REGULATED,
TachoLimitField, 0,
PowerField, 0,
long rc = MotorRotationCount(output);
long oldrc = rc+1;
while (oldrc <> rc) {
oldrc = rc;
Wait(10);
SetOutput(output, OutputModeField, OUT_MODE_COAST+OUT_MODE_REGULATED,
TachoLimitField, 0,
PowerField, 0,
RunStateField, OUT_RUNSTATE_IDLE,
UpdateFlagsField, UF_UPDATE_MODE);
bool bDone = false;
task MoveMotors()
RotateMotorRURD(OUT_A, 75, 720);
Wait(500);
RotateMotorRURD(OUT_A, 75, -720);
Wait(500);
Wait(500);
Wait(500);
Wait(500);
Wait(500);
bDone = true;
task MonitorMotors()
while (!bDone) {
ClearScreen();
NumOut(0, LCD_LINE1, MotorRunState(OUT_A));
NumOut(0, LCD_LINE2, MotorMode(OUT_A));
NumOut(0, LCD_LINE3, MotorRotationCount(OUT_A));
Wait(1);
Precedes(MoveMotors, MonitorMotors);
ResetRotationCount(OUT_A);
Wait(5);
