[NXC][Bug] Different type comparisons
Re: [NXC][Bug] Different type comparisons
muntoo wrote:This bug was torturing me in NXTFileManager. :)
This is definitely a bug. But please, please, please stop mixing signed and unsigned types willy-nilly. It is nonsense. Only use an unsigned type when it is absolutely necessary. It is only absolutely necessary when you are dealing with values > MaxInt and generally that only involves things like CurrentTick(). Mixing signed and unsigned types in a ?: expression does not make any sense (and, apparently, is currently broken).
I think that I have a fix in place for this defect. Basically I added a call to CastToLHSType after the two CommaExpression calls in the code block that handles ?: expressions. If the lhs type is defined and not equal to the statement type of the last CommaExpression then the value in the register used last is moved into the register for the lhs type (signed, unsigned, or float).
With this change the ASM code without optimizations looks like this:
	set __D0main, 441
	mov __main_7qG2_ui_7qG2_000, __D0main
	set __D0main, 64
	mov __main_7qG2_l_7qG2_000, __D0main
	mov __D0main, __main_7qG2_l_7qG2_000
	mov __signed_stack_001main, __D0main
	mov __DU0main, __main_7qG2_ui_7qG2_000
	cmp 0, __D0main, __signed_stack_001main, __DU0main
	brtst 4, __ASM_Label_610, __D0main
	mov __DU0main, __D0main ; this line of code is generated by CastToLHSType
	jmp __ASM_Label_611
__ASM_Label_610:
__ASM_Label_611:
	mov __main_7qG2_len_7qG2_000, __DU0main
At optimization level 3 it looks like this:
	set __main_7qG2_ui_7qG2_000, 441
	set __main_7qG2_l_7qG2_000, 64
	cmp 0, __D0main, __constVal64, __DU0main
	mov __DU0main, __main_7qG2_l_7qG2_000 ; extra mov is optimized out
	jmp __ASM_Label_611
__ASM_Label_610:
__ASM_Label_611:
