NXC: Keep Alive
fuzzball27
NXC: Keep Alive
How does the Keep Alive function work in NXC? I looked it up in the .defs and poked around with it, but I couldn't figure it out.
fuzzball27 >>-->
Re: NXC: Keep Alive
I don't know, but I am guessing it has to do with the shutoff timer that the NXT uses. Normally if you don't use the NXT for a set amount of time (10 minutes for example), then it shuts off. Pressing the buttons seems to reset the 10 minute timer, and probably that command does the same thing.
BTW, it is by no means limited to just a 10 minute timer with Lego FW.
Re: NXC: Keep Alive
Yep, exactly what mattallen37 said!
fuzzball27
Re: NXC: Keep Alive
Alright so I'm guessing if I did something like this would it do the job:
I wonder if receiving Remote BT firmware commands still works? (eg. Master sends "RemoteSetOutputState" to brick running "KeepAlive" Function.)
task main () {
while(true) {
KeepAlive();
Wait(10*6000);
fuzzball27 >>-->
fuzzball27
Re: NXC: Keep Alive
Never mind! I found a better way to do it in the .defs "RemoteKeepAlive"
But I'm getting a strange error...
Here's my code segment:
Here's the error:
while (true) {
Wait(6000*5)
Acquire (BT_Mutex);
RemoteKeepAlive(CONN_BT0);
Release (BT_Mutex);
#Error: Preprocessor macro function does not match instance (__connectionSCDCWrite(_conn,__DCKeepAlivePacket,_result))
fuzzball27 >>-->
Re: NXC: Keep Alive
If by "remote BT firmware commands" you mean the "direct commands", then yes: This still works while RXE programs (produced by e.g. NXC or NXT-G) are running. This is true for all direct commands. And from my tests, the direct commands don't even afffect the running RXE's performance...fuzzball27 wrote: I wonder if receiving Remote BT firmware commands still works? (eg. Master sends "RemoteSetOutputState" to brick running "KeepAlive" Function.)
Btw, you don't really need the keep alive if you set the NXT's sleep timer / auto off to "never", then it stays always on...
Re: NXC: Keep Alive
I think that if you set the sleep timer value to 0 within the NXC program it never goes off.
Re: NXC: Keep Alive
I believe that this has been fixed in one of the more recently posted test releases. The fix will be in the next official release as well. Once I get my boolean expression code generation up to par I should be about ready for an official release.fuzzball27 wrote:Code: Select all
Re: NXC: Keep Alive
If you want to have an NXC program keep *this* brick awake regardless of its user-configured sleep timer value then you have your program call ResetSleepTimer() periodically (i.e., in a loop that executes throughout the lifespan of your program's execution). Or you can call SysKeepAlive. See the help for these two functions.fuzzball27 wrote:How does the Keep Alive function work in NXC? I looked it up in the .defs and poked around with it, but I couldn't figure it out.
If you want to have an NXC program keep some other brick awake by sending it a direct command (KeepAlive) via Bluetooth then you have your program call RemoteKeepAlive. You do not use RemoteKeepAlive to keep *this* brick awake.
fuzzball27
Re: NXC: Keep Alive
My intention was to Keep a Separate brick alive.If you want to have an NXC program keep *this* brick awake regardless of its user-configured sleep timer...
fuzzball27 >>-->
Users browsing this forum: No registered users and 39 guests
