Bricxcc?
fuzzball27
Bricxcc?
I've got a mac and I want to check out bricxcc but it doesn't seem to work...it doesn't even open. Does anyone know what might be wrong?
fuzzball27 >>-->
Re: Bricxcc?
BricxCC is a Windows program. That might be your problem.
Try nxtcc instead, it 's a version of BricxCC for *nix (Mac, Linux)
Re: Bricxcc?
fuzzball27
Re: Bricxcc?
If nxtcc does not load on your Mac then perhaps you do not have the required Fantom drivers installed? These can be download from the LEGO MINDSTORMS support pages on the LEGO website.
http://cache.lego.com/upload/contentTem ... 5DA785.zip
fuzzball27
Re: Bricxcc?
I already have those, but I'll re-download just in case. I've been cleaning up/organizing my NXT files, and I may have accidentally deleted them somehow? I'll find out if re-downloading does the trick...
fuzzball27 >>-->
fuzzball27
Re: Bricxcc?
No luck. I got a crash report though... It looks like the first/main thread is failing.
Here's the first part of the crash report if it helps any:
Process: nxtcc [1320]
Path: /Users/USER/Desktop/nxtcc.app/Contents/MacOS/nxtcc
Identifier: nxtcc
Version: ??? (1.0)
Code Type: X86 (Native)
Parent Process: launchd [142]
Date/Time: 2011-08-09 19:53:57.947 -0400
OS Version: Mac OS X 10.7 (11A511)
Report Version: 9
Interval Since Last Report: 340564 sec
Crashes Since Last Report: 16
Per-App Interval Since Last Report: 166 sec
Per-App Crashes Since Last Report: 8
Anonymous UUID: FC70276E-60F1-41D1-B96A-B721E655F46C
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
/Library/Frameworks/nipalu.framework/Versions/1/nipalu
objc[1320]: garbage collection is OFF
abort() called
fuzzball27 >>-->
fuzzball27
Re: Bricxcc?
I have the same problem with NXT Tools. NXT Tools used to work just fine for me.
fuzzball27 >>-->
fuzzball27
Re: Bricxcc?
Here's something really strange...both the most recent version, and the previous 2010 version of the nbc compiler are telling me that "task main ()" is an invalid command??
[img]NXC%20Errors.tiff[/img]
fuzzball27 >>-->
Re: Bricxcc?
Sounds like there is a problem with nxtcc and Lion - possibly in the FreePascal/Lazarus code or, perhaps, in the Fantom drivers.
It is always helpful to reveal as much as possible about your situation as you can when you are having trouble and seeking assistance. So "I have a mac" could be replaced by "I have an intel mac running OS X Lion" or whatever.
If you are running Lion then you might try booting your mac in 32-bit mode rather than 64-bit mode. Or choose the "open in 32 bit mode" (try googling this").
For now, I am sticking with Snow Leopard on my intel mac mini.
Users browsing this forum: Semrush [Bot] and 43 guests
