NXC: strlen vs. StrLen
hello,
for NXC: what are the differences between strlen vs. StrLen ?
Re: NXC: strlen vs. StrLen
AFAIK, StrLen was renamed into strlen so that it correspond to the C function. StrLen still exists for backwards-compatibility. There is a couple of functions that are like that, however some might be macro versions, while others aren't iirc.
Anyway, both functions both uses ArrLen and then subtract one, no matter where NULL actually is...
2/07 test release, level 2 optimization.
StrLen():
task main(){
StrLen("Hello, world");
produces
dseg	segment
;------- definitions -------
;------- declarations -------
__D0main	sdword
____initialize_global_data_return	byte
__constVal1	sbyte	1
__constStr0009	byte[]	'Hello, world'
__strbufmain	byte[]
dseg	ends
;------- code -------
thread main
	subcall __initialize_global_data, ____initialize_global_data_return
	strcat __strbufmain, __constStr0009
	arrsize __D0main, __strbufmain
	sub __D0main, __D0main, __constVal1
	exit -1, -1
endt
subroutine __initialize_global_data
	subret ____initialize_global_data_return
ends
strlen():
task main(){
strlen("Hello, world");
produces
dseg	segment
dseg	ends
thread main
	exit -1, -1
endt
ends
I would not prejudge your evaluation now - but at first glance, it looks as if strlen code is shorter...
any other significant differences?
I don't know, it appears smaller and faster, but i'm a n00b at reading asm
It also appears the call has been omitted from the version using strlen()
Please be aware that the optimizer might remove unneeded code and this is why the second program is smaller, it is simply empty...
Remember to use TextOut/NumOut or at least something to make sure the calculated values are actually used. (It is interesting that only one of the functions disappear though.)
Here's the code without it being removed by the optimizer:
  NumOut(0, LCD_LINE1, strlen("Hello, world"));
	mov __strlen_7qG2_str_7qG2_000_inline_main, __strbufmain
	arrsize __D0strlen_inline_main, __strlen_7qG2_str_7qG2_000_inline_main
	sub __D0main, __D0strlen_inline_main, __constVal1
  NumOut(0, LCD_LINE2, StrLen("Hello, world"));
