How I would love to have the former .ini files of the good old days of Win95/98 which you could edit with any text editor.
Bricxcc and firmware test versions
Re: Bricxcc and firmware test versions
Am I the only one who hates registry entries? To me it's tortures down to the bones.
It worked! I changed the value to 1, and that seems to have done it. Thanks a lot for all your help!
(Thanks for the zip.)afanofosc wrote:The thing (or one of the things) I found confusing was that calling ArrayInit(data, 10, 1000) on a byte array that was previously empty did not result in the PoolSize going up by ~1000 and when I copied it to another byte array that was previously empty it didn't go up further.
I tried raising a byte array slowly and got the following data:
PoolSize Dataspace
0 204 108
1 205 109
2 206 110
3 207 111
5 209 113
10 214 118
15 219 123
20 224 128
25 229 133
50 254 158
51 255 159
52 0 160I was using the following piece of code for the testing:
//test2.nxc
task main(){
byte test_array[];
ArrayInit(test_array, 0, 143);
int ps, ds;
GetMemoryInfo(true, ps, ds);
TextOut(100, LCD_LINE1, test_array);
NumOut(0, LCD_LINE1, ps);
NumOut(0, LCD_LINE2, ds);
Wait(6000);
}My blog: http://spillerrec.dk/category/lego/
There was a bug in the implementation of the MemoryManager system call. I have fixed that and uploaded a new test version of the firmware image here:
http://sourceforge.net/projects/bricxcc ... p/download
The numbers definitely look more reasonable now.
Can you post a version of the firmware without try me and nxt datalog menus?
Using a void like this doesn't work anymore.
It doesn't make the point move diagonal.
int x;
int y;
void Jump(int & sx, int & sy)
sx++;
sy++;
task t1()
while(1)
PointOut(x,y);
Wait(50);
task t2()
while(1)
Jump(x,y);
Precedes(t1,t2);
Can you point me to a firmware version where your code did produce a diagonally moving point? There have been no recent changes to the drawing operations in the enhanced NBC/NXC firmware. The second task should execute Jump many times more frequently than the PointOut call is executed in the first task. The word "void" is not a proper term for a function or procedure. Just refer to it as a function or a procedure.
The firmware is the most recent version. The PointOut works, but using the int & sx doesn't work.
It compiles, but doesn't write the variable x to the value of sx.
I'm not seeing the same results you are with the latest BricxCC and firmware test versions (which this thread is about).
In 50 milliseconds, i.e., before PointOut draws its second point, the x and y values have been incremented way beyond 63, 63 which would be the last visible dot as x and y are incremented upwards. Try this program:
As you can see, x and y are incremented and the dots are drawn diagonally upward from (0, 0).
int x=0;
int y=0;
sx++;
sy++;
task t1()
while(1)
PointOut(x,y);
Wait(500);
task t2()
while(1)
Jump(x,y);
NumOut(0, LCD_LINE8, x);
NumOut(50, LCD_LINE8, y);
Wait(500);
Precedes(t1,t2);
But this only returns x and y at the end of the function.
int x=0;
int y=0;
repeat(5)
sx++;
sy++;
task t1()
while(1)
PointOut(x,y);
Wait(500);
task t2()
while(1)
Jump(x,y);
Wait(500);
Precedes(t1,t2);
