I have made a little Demo of the OpenGL NXC 3d functions controlled by a wii nunchuk:
NXC 3D Engine and a Wii Nunchuck
sebi-mylegopage
Re: NXC 3D Engine and a Wii Nunchuck
Can you post the program?
sebi-mylegopage
Yes. But I will make tomorow a "clean copy":
byte CMDNunchukInit[] = {0xA4, 0x40, 0x00};
byte CMDNunchukWrite[] = {0xA4, 0x00};
byte CMDNunchukRead[] = {0xA4};
byte nbytes;
byte outbuf[];
// port is the NXT port
// i2c_cmd is the nunchuk internal address register
// at i2c_cmd=0...5 are 6 Byte of sensor values
// at i2c_cmd=0x20 ... 0x2F you get 16 Byte of calibration data
sub NunchukGetParamter(byte port, byte i2c_cmd)
// Initialize the Nunchuk
SetSensorLowspeed(port);
LowspeedWrite(port, 0, CMDNunchukInit); //ask for 0 bytes
while(LowspeedStatus(port, nbytes)>0);
// Wait(1) is needless, the NXT command interpreter delays next i2c access 3ms
CMDNunchukWrite[1] =i2c_cmd; //at 0x00: 6 Bytes of sensor values
LowspeedWrite(port, 0, CMDNunchukWrite); // write Nunchuk register address
byte count = 6;
LowspeedWrite(port, count, CMDNunchukRead); //ask for count bytes
if(nbytes == count){
LowspeedRead(port, count, outbuf) //read data from buffer
for(int i=0; i<count; i++ ){
outbuf[i]=(outbuf[i]^0x17) + 0x17;
else {
ArrayInit(outbuf,0,0); //error
int angleX, angleY;
// Initialize the 3D engine...
glInit();
// Create a box, this is the first object which will be object id 0...
glBox(GL_POLYGON, 10, 20, 30);
// Create a box, this is the second object which will be object id 1...
glBox(GL_POLYGON, 30,40,50);
//glSetAngleX(0);//100
//glSetAngleY(0);//125
angleX = 0;
angleY = 0;
while (true)
// Setup for rendering...
glBeginRender();
// Call the object with id 0...
glCallObject(0);
glObjectAction(0, GL_ROTATE_X, angleX);
// Call the object with id 1...
glCallObject(1);
glObjectAction(1, GL_ROTATE_Y, angleY);
// Finish, clear the screen, rotate and render the called objects...
glFinishRender();
NunchukGetParamter(S1, 0x00);
if (ArrayLen(outbuf)==6)
glBeginRender();
glCallObject(0);
//NumOut(0,0,(outbuf[0]),false);
//NumOut(0,10,(outbuf[1]),false);
glObjectAction(0, GL_ROTATE_Y, (225-outbuf[0]));
glObjectAction(0, GL_ROTATE_X, (outbuf[1]));
glCallObject(1);
glObjectAction(1, GL_ROTATE_Y, ((225-outbuf[2])*3));
glObjectAction(1, GL_ROTATE_X, (outbuf[3])*3);
glFinishRender();
//Wait(1000);
}Re: NXC 3D Engine and a Wii Nunchuck
Nice
I tried the NXC 3D engine, the ease of use is quite impressive!
Awsome!!!! i like 3D!!!!
Oh, and i would like it if you made a small program like that, but one box and uses the Enter, Left, Right, and Exit button.
2Labz.com, My Website
stryker001
I'm trying to learn how to do this... can anyone help?
- Stryker AKA Jordan
Have you seen my NXC GL post? Also, the documentary might help. (Rightclick a command in BricxCC, then select 'help topics'.)
