Reading from multiple lines in a File
logebotmaster
Okay, I know how to write multiple lines into a file on the NXT, and it's proven very helpful in creating readable .txt datalogs. What my question is, is it possible for the NXT to retrieve information from a file in any of the written lines instead of just the last recorded line? And also, is it possible to accurately retrieve data from a .txt file? Thanks
Botmaster
Botmaster
Re: Reading from multiple lines in a File
Well, with NXC, Yes, and Yes.
Assuming it's in string format, you may want to check out ReadLnString().
I can't edit my post...
Anyways, here it is again:
@Matt, I think that the OP was also asking "how".
I believe it works like this:
void ReadLines(string &out[], string filename)
byte handle;
unsigned int fsize;
ArrayInit(out, "", 0);
if(OpenFileRead(filename, fsize, handle) == LDR_SUCCESS)
// Yes, I know I'm becoming more and more like the guys at IOCCC
for(string szBuf; (ReadLnString(handle, szBuf) == LDR_SUCCESS); ArrayBuild(out, out, szBuf));
CloseFile(handle);
I suppose you are likely right. Here is an example of the method I use.
if(OpenFileRead("File.txt", size, handle) == NO_ERR)
until (Sdone == true) // read the text file till the end
if(ReadLnString(handle,message) != NO_ERR) Sdone = true;
//You need to grab the message and write it to another string(or whatever you need to do) all right here.
//Base it on an increasing variable, like the following lines.
TotalMessage[i]=message;
i++
}Matt
[quotename=mattallen][/quote]
I need to write this to the variable "Sen". Can you modify this
program to do this?
And how does muntoo do the "Show" thing????
i++
}I need to write this to the variable "Sen". Can you modify this
program to do this?
2Labz.com, My Website
Anyways, enough fooling around before Xander gets tempted to remove the "Show button"
byte handle;
unsigned int fsize;
CloseFile(handle);
string Sen[];
ReadLines(Sen, "File.txt");
}Commit to LEGO Mindstorms Robotics Stack Exchange:
Sen is a string (not array). I like your idea. Thanks... half
If Sen is JUST a string, I don't get why you don't just do this:dudmaster wrote:Sen is a string (not array). I like your idea. Thanks... half
OpenFileRead(fname, fsize, handle);
Read(handle, Sen);
//Or if that doesn't work:
ReadBytes(handle, fsize, Sen);
//Or
char cSen[];
ReadBytes(handle, fsize, cSen);
CloseFile(handle);
logebotmaster
Thanks all, very interesting indeed.
Botmaster
Botmaster
