Hey everyone,
I am wondering if it is possible, using NXC, to turn on the bluetooth programmatically, instead of manually through the FW menu. Any ideas?
I see I can check the state, using BluetoothState(), but not setting the state.
Why? Well, sometimes for "no reason", when I start the NXT, the Bluetooth is off. I actually wonder why does it turn off by itself. It is very rare, but it happens.
Thank you!
Turning Bluetooth on, on the NXT through an NXC program
ricardocrl
pepijndevos
Re: Turning Bluetooth on, on the NXT through an NXC program
I looked through the docs, as I'm sure I did this in pbLua, but I can't find it fro NBC. I hope someone else does.
-- Pepijn
tabbycatrobots
Will the command SysCommBTOnOff do what you need?
ricardocrl
Awesome!! That's it! Bad search I did.
Thank you very much!
Cheers!
Cheers!
