Bluetooth send float
mcsummation
Post by mcsummation »
I would like to be able to send a float from an NXT up to the PC using Bluetooth. If someone would tell me where to find the implementation of SendResponseNumber is located, I can implement SendResponseFloat and provide the code for others.
Re: Bluetooth send float
Here's the underlying implementation from NXTDefs.h:
#define __sendResponseNumber(_queue, _val, _result) \
  acquire __MWMutex \
  add __MWArgs.QueueID, _queue, 10 \
  mov __SRNTmpVal, _val \
  flatten __MWArgs.Message, __SRNTmpVal \
  syscall MessageWrite, __MWArgs \
  mov _result, __MWArgs.Result \
  release __MWMutex
#define __sendResponseString(_queue, _msg, _result) \
  acquire __MWMutex \
  mov __MWArgs.Message, _msg \
  release __MWMutex
You can use something like this:
#define SendResponseFloat(_queue, _val) \
  asm { \
  acquire __MWMutex \
  flatten __MWArgs.Message, _val \
  mov __RETVAL__, __MWArgs.Result \
  release __MWMutex \
The existing SendResponseString could also be used like this:
inline char SendResponseFloat(byte queue, float val)
  string tmp = FlattenVar(val);
  return SendResponseString(queue, tmp);
These are completely untested.
mcsummation
After crawling through the code dribbled out to the .sym file, I finally came up with a couple of functions:
     byte _local_buffer[5];
     byte _local_queue = queue + 10;
     asm
        flatten _local_buffer, val
     _local_buffer[4] = 0;
     return(SendMessage (_local_queue, _local_buffer));
char ReceiveRemoteFloat(byte queue, bool clear, float & val)
     bool bErr;
     float _local_default = 5;
     char cError;
     cError = ReceiveMessage (queue, clear, _local_buffer);
     asm
        unflatten val, bErr, _local_buffer, _local_default
     return(cError);
These may not be as good as yours (I'm still trying to come to grips with NBC), but they are working for me.
I've been writing code for 50 years; however, I can always find new ways to "bother" a computer and its various languages. :geek:
You can see the NBC code generated by the compiler if you are using BricxCC without resorting to the .sym file by simply pressing F12.
mcsummation
Since the .sym file has line numbers in it, I find it easier to dig through.
I just started on BricxCC, NBC, and NXC last week, so I've still got a LOT to learn. Although, all of these bear striking resemblance to tools/assemblers/compilers I've used in the past.
mcsummation
A problem I ran into was that, using opt=2 in the NXC compiler, caused the brick to hang. I had to use opt=1 (or 0) to get the code to run. Is there some glitch with opt=2? Or did I do some foolish thing?
Edit: Should have included that I'm using BricxCC 3.3.8.9, 1.31 (from Lego) FW, and compiler options of: Use Internal Compiler, Enhanced Firmware, not Ignore system include files, NXT 2.0 compatible firmware, Automatic firmware version, and RICScript.
using NXC it's always better to download the latest enhanced firmware, I would suggest to change this at first.
mcsummation
I downloaded the current "test release" from http://bricxcc.sourceforge.net/test_releases/ and my code works for all opt levels of the NXC compiler.
Thanks for nudging me in the direction of loading a "test release" on my brick + BricxCC.
you're welcom!
I guess "nudging " is something meant to be taken nicely or so although I actually have no idea what that means (even Google translate doesn't) ^^
mcsummation
to nudge: verb
Prod (someone) gently, typically with one's elbow, in order to draw their attention to something.
Yes, it's meant in a friendly way.
