Hi everyone
If I start amending a program before connecting to the RCX and then take the Find Brick option from the tools menu the program ceases to respond. Even Task Manager cannot delete the process - generally I can reboot which is irritating - once I had to unplug the power cable and pull the battery (which is worse than irritating). Any ideas?
Win 7 PC freezes on Find Brick (RCX2)
inxt-generation
Re: Win 7 PC freezes on Find Brick (RCX2)
Do you have 32-bit or 64-bit system?
A.K.A. NeXT-Generation.
foamcleaver
Sorry - I should have said - its 32 bit. Thanks for your reply.
inxt-generation
Have you tried the latest USB tower driver?
foamcleaver
I think so; I'm using the one at http://www.robotc.net/files/rcxdriver.zip. See the thread just below this one in the Hardware forum.
inxt-generation
I would try the one I linked to. It is the the one afanofosc (A.K.A. The creator of bricxcc) suggests
foamcleaver
Spot on. It fixes the freeze problem as well as the problem in the previous thread. What would I do without you guys - thanks.
Users browsing this forum: Ahrefs [Bot] and 3 guests
