RotateMotorEx Problem
fuzzball27
Post by fuzzball27 »
I'm working on a project that requires precision movements, and for whatever reason I get a problem with this bit of code:
RotateMotorEx(BOTH, 75, DEGREES, 0, true, true);//BOTH is OUT_AC, DEGREES = 180
RotateMotorEx(BOTH, 50, TURN_90, 100, true, true);//TURN_90 = 220
RotateMotorEx(BOTH, 75, DEGREES/2, 0, true, true);
The third line causes the robot to turn at full power. Am I missing something?
fuzzball27 >>-->
pepijndevos
Re: RotateMotorEx Problem
Post by pepijndevos »
I think RotateMotor puts the motor in REGULATE_SPEED, which means that it might indeed accelerate to full power to turn at the desired actual speed.
At least in my experience, depending on the load, you have to use much less power with speed regulation than with directly controlling the power.
-- Pepijn
Users browsing this forum: Baidu [Spider], Semrush [Bot] and 30 guests
