NXC float
roboteer
NXC float
Post by roboteer »
I ran the following simple code and the NXT 2.0 brick just hangs. I keep hearing some ticks but nothing else happens. I upgraded the firmware to 1.31 to make sure but that did not help. Does anyone have any ideas? I assume that float variables are supported in NXT 2.0. Here is the code snippet that causes the problem.
#define Kproportional 6
task main(){
int error = 0;
float proportional = 0;
proportional = Kproportional * error;
Thanks for the help. 8-)
Re: NXC float
It runs just fine for me. I am using version 1.32 of John's EFW.
Try this so you can actually see the result:
task main(){
  int error = 0;
  NumOut(0, LCD_LINE1, proportional);
  while(true);
Although with an error of 0, the result should be 0 (6*0=0).
mcsummation
Re: NXC float
Post by mcsummation »
roboteer, I had a similar problem with float when I first started using NXC. However, I can't remember what the problem turned out to be. It was something really simple though. (I suffer from CRS = Can't Remember Stuff. :( )
Re: NXC float
Oh, make sure you have your FW related compiler settings set according to your NXT FW version.
mcsummation
Re: NXC float
What version of the compiler and BricxCC are you using?
nxtboyiii
Re: NXC float
Post by nxtboyiii »
And you have the latest enhanced firmware?
roboteer
Re: NXC float
Post by roboteer »
Yup, I got it working. I had a very old version of the firmware installed. By the way, it matters how the color sensor is physically installed. I installed it on the back of the robot and my program now drives it backwards around the track. In case anyone wanted to know.
Thanks for all the help.
