Moving heavy objects
circuitmage
Post by circuitmage » 21 Nov 2013, 17:45
I have a project I'm working on that requires rotating a small 3-5 lbs object and I'm looking for suggestions or examples of ways the NXT (motors) can handle that.
Since I don't have to actually grab anything, it seems like a simple project, but have found a few issues. Mainly handling the weight is the problem.
I have built a basic frame for what I need, and have revised it several times already. Sorry, cannot go into detail as I'm hoping I can use this at work.
But some basic concepts I am using / coming to grips with are;
* Center of gravity. Keeping item centered to avoid balance problems.
* Using more than 1 motor. Already having issues with controlling power with 1 motor.
* Rotational momentum. Think I need to gear down to control this. I'm at 1:2.33 now, and still have issues. More than 1 motor may solve this issue.
* Holding item down? I'm hoping gravity will do the work for me. Some rubber parts should keep the thing in place.
* Struts/caster supports. I have some good struts in my frame, but may need additional support for the weight. Thinking about adding casters the the bottom to keep it level...
Any examples/ideas along these lines would be great.
circuitmage
Re: Moving heavy objects
Post by circuitmage » 22 Nov 2013, 14:46
Ok...so after more research, and build revisions I have found the following;
~40lbs movable on lego bearings on youtube.
I added a 2nd motor to my turntable and run both at 50% power. Seems to work well for 3lbs.
I still have some work to do on my frame, and this will take some time....
Post by h-g-t » 22 Nov 2013, 16:59
If it is acceptable why not wrap a Lego chain round it and drive that using a standard gear?
I
circuitmage
Post by circuitmage » 22 Nov 2013, 20:02
I am considering something along those lines. The object is cylindrical and smooth, so I could use a couple rubber treads to grab onto it. My only concern is if it slips. Since the object is smooth it is susceptible to slipping and as I am moving it frequently, any loss of movement is unacceptable.
So right now I have it balanced over two large wheels about 3 inches apart which are directly driving the object. This is working OK, but because of the weight of the object I need to support the entire assembly a little more.
I have also considered "clamping" down on the object to keep it in place, but I am still hoping gravity will do that work for me.
I am concerned about the long-time wear on the plastic gears. With two motors driving 24t gears to a turntable (56t) at 50%, I think it is OK.
I am also concerned about direct drive on a 3-6 lb. object (just spinning it). But so far, the two large wheels are doing it. If I can take more pressure off the wheels (and motor in return), then it should help.
Post by h-g-t » 22 Nov 2013, 23:51
I had a similar situation although the forces involved were not nearly so great.
I rolled out some BluTak into a long worm about 3-4mm diameter and applied that to the surface, then squeezed Lego chain down over that.
The chain was driven by a standard gear which was turned using a worm drive, giving a very low gear ratio so it may be too slow for your purposes.
To minimise wear, I applied graphite grease to the worm drive, but this runs only intermittently so I don't know how long the gears will last.
To avoid over-straining the chain, the speed could be ramped up slowly.
If non-Lego parts are acceptable, there are a variety of metal or heavy duty plastic chains available, for instance.
http://www.smallparts.com.au/search/res ... 3A11&hl=en
I also saw a device where a Spanish Windlass was used, i.e. a long string wrapped round the object and a small axle. The tension helps to keep the string from slipping.
That device used a circular wooden turntable resting on 3 wheels for support.
String went round a groove in the edge.
datbikerguy
Post by datbikerguy » 14 May 2014, 16:24
I agree with h-g-t. If you can use non-Lego parts. I would definitely go with metal for the gears and chains.
I am not exactly sure how you are trying to shape your robot but I would look at this framing.
http://www.nxtprograms.com/trailer_pull/steps.html
(One problem is that this robot cannot turn. But it can be modified to turn.
Hope that helps.
